4cyl third into v6 housing?
Old Dec 30, 2008 | 12:42 PM
Hophead's Avatar
Looks like I need to replace my rear third - I have found a 4.56 third locally but the owner does not know if it is a 4cyl or V6 third. Will a 4cyl third bolt right up? Or is there any issues with the drivshaft flange and/or axel spline count? Help!
Old Dec 30, 2008 | 12:58 PM
Beaniam's Avatar
The axle housings are identical
Old Dec 30, 2008 | 01:38 PM
trbizwiz's Avatar
I believe the difference is 4 spider gears versus 2 spider gears for the 4 cylinder. I don't think it will adversely effect you one way or the other. Where you get into trouble is with the rebuild kits you need the right gears and bearings then, but for a component swap either is fine, v6 is probably a little stronger.
Old Dec 30, 2008 | 02:52 PM
91 4Runner's Avatar
So in short - Yes. they will bolt in... No issues...
Old Dec 30, 2008 | 03:06 PM
TOYOTA 1's Avatar
bolts right up! the flange might be different but can be swaped.
Old Dec 30, 2008 | 07:10 PM
Hophead's Avatar
Thanks for the replys! Thats what I thought. Ends up the diff was perfect- V6 4.56-will bolt right up.
Old Dec 30, 2008 | 07:58 PM
86Toyrunna's Avatar
ya they will interchange.. flanges are possibly different, just have a 30mm socket to swap em. the v6 third casting is much beefier and is a stronger third but the 4banger will hold up fine
bobpat
Sep 1, 2015 07:25 AM
colsoncj
Ozarks
35
Oct 22, 2008 10:00 AM
deserttoy84
Feb 7, 2008 03:21 PM
Cougarfreak
May 24, 2007 09:48 AM
shaeff
Feb 28, 2007 01:24 PM
