4 Wheel Drive Question??
Old Feb 18, 2007 | 10:50 AM
yotasavg's Avatar
i've always engaged 4lo going a few mph. but i never do it above 4 or 5. i don't even want to try it. between 2hi and 4hi, i do it at 50-60mph no problems
Old Feb 18, 2007 | 12:44 PM
LS1Steve's Avatar
Originally Posted by slosurfer
Me too, with the stupid automatic tranny, I constantly have to shift between 4H and 2H to keep any type of speed. Although I haven't regeared yet, so I don't reach quite those speeds in the sand.
what tire pressure do you run? I had major power problems when I used to run at full pressure, now I drop down to 8psi and man, going uphill on a dune is no different to the engine than going up the same incline on a paved road
Old Feb 18, 2007 | 02:51 PM
slosurfer's Avatar
I usually run at least that low, I think the main thing is that I haven't regeared to 5.29's yet. I usually shift to 4hi when I start to lose traction going up a dune. It doesn't help that I have a tranny temp gauge, I drive much more conservatively now.
Old Feb 18, 2007 | 11:10 PM
the_supernerd's Avatar
The sticker on my glove box is consistant with the information here. It says no more than 50 MPH between 2 high and 4 high and 5 MPH between 4hi and 4 low. I usually stop for 4L, but I have occasionally double-clutched out of it a few times going faster that 5 MPH. I do not do that often because I am not perfect and it usually grinds a little.
Old Feb 18, 2007 | 11:21 PM
  #25
fork's Avatar
Originally Posted by errol
quoted from my 1992 owners manual..
" d) shifting procedure: 3vze engined vehicles with automatic transmission
shifting between h2 and h4: move the front drive control lever with the lock release button depressed.
the indicator light may not come on even if you shift into h4. if the vehicle is stopped, starting out the vehicle will turn it on. if the vehicle is moving, depress or release the accelerator pedal slightly.
***caution*** never move the front drive control lever if the wheels are slipping. stop the slipping or spinning before shifting.
to shift from h4 to h2:, simply move the front drive control lever with the lock release button depressed. the vehicle may be moving at any speed...
shifting between h4 and l4. reduce your speed to less than 18mph(30 km/h) and move the front drive control lever with the lock release button depressed.
to move from l4 to h4, simply move the front drive control lever. the vehicle may be moving at any speed."
side note... as i re-read this it seems as though there is no maximum speed(or any speed at all) listed for shifting from h2 to h4 for the 3vze. if the 22re trans is the same(which i doubt) then you have to "reduce your speed to less than 50 mph" to shift from h2 to h4.
taken from the page before the 3vze data...
i hope this all helps. i wrote exactly what was in the owners manual...
awesome post. When I wheel I frequently keep it in 2wd low and use my brakes. I only stick it in 4 if I know I need it. Occasionally in mud I shift from 4lo to 4hi to get more spin. I always wondered if shifting from 4lo to 4hi and 4hi to 4lo while moving was going to beat up my xfer case much..
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
skoti89
Jul 6, 2015 07:45 PM
