4" Backspacing ok?
Old Jul 27, 2008 | 04:23 PM
Trustyrusty's Avatar
Alrighty... Yeah I'm not concerned with that but thanks anyways! Haha Its basically just a trail rig, and I DD it about 40% of the time..
Old Jul 27, 2008 | 05:09 PM
Jay351's Avatar
Its okay, just keep up on your matenence. My truck is my DD
p.s slap your friend! Just mount the rims/tires and whereever it rubs pound with a hammer..
Old Jul 27, 2008 | 06:41 PM
Well it WAS my idea to hit said snow penis, the valance already had a huge dent in the middle from hitting a dog three days after owning the truck.. I hit some black lab after it ran infront of me and I looked up and it was nowhere to be seen, hopefully its ok.. or WAS ok..
Old Jul 27, 2008 | 06:45 PM
Oh yeah just ordered my performance accessories 3" Body Lift and white wagon wheels with 3.75" backspacing from www.summitracing.com, total was like 260 bones with shipping, wheels were 35 a piece, if I don't like the white I can rattle can 'em.. Hey Jay, did you get shifter extensions with your kit? Everything have enough slack? I'm hoping my gear shifters won't interefere with each other.. but if it does I have a torch..
Old Jul 27, 2008 | 06:49 PM
  #25
abecedarian's Avatar
4crawler has some stuff here about extensions: http://4crawler.com/4x4/ForSale/Body...lTransmissions
but you might want to look for a 'short shift' kit.
Old Jul 27, 2008 | 06:52 PM
  #26
Read it already.. I'd rather cut the shifters and weld them then hack up my floorboards n stuff..
Old Jul 27, 2008 | 06:54 PM
  #27
oh kay... so I guess the 2" and 3" extensions aren't what you're looking for...
(having trouble with understanding the 'hack up the floorboards' though...)
sounds like a short shift kit with lever extensions is what you want.
Old Jul 27, 2008 | 06:56 PM
  #28
the extensions PA is supposed to send you are 3" lengths of 1/2" steel that you cut your shifter near the base and weld onto to raise it up to avoid shifter bindage and whatnot, if you don't do this sometimes you have to cut the metal plate and part of your floorboard to get the shifters to not interfere with that..
Old Jul 28, 2008 | 01:13 PM
  #29
bigtrucknwheels's Avatar
thats only a body lift, correct?
Old Jul 28, 2008 | 01:17 PM
  #30
Mic09dcsm's Avatar
So what about a 10 inch rim with 4 inch backspacing?
Old Jul 28, 2008 | 01:18 PM
  #31
Jay351's Avatar
Yep, I got the 2 3" peices of cold rolled steel. I had a guy cut and weld them in where the instructions specify (there is a specific spot to cut+weld). When we installed them my shifter was hitting the t-case shifter in reverse. So we dissasembled the two peice shifter (to keep it from burning) heated and bent the shifter up and to the left. In hindsight I wouldve bent the t-case shifter instead. That gave me tons of clearance but I was still having a little trouble with reverse, I did the shifter boot invert mod (not really a mod ) and that gave me full use of all gears.
I didnt have to trim or bend the floor to clear anything
p.s good call on the wagon wheels
Old Jul 28, 2008 | 02:20 PM
  #32
What is this shifter boot inverting everyone is talking about? will I have to do this? You'd think if I cut and welded in the correct spots I wouldn't have any problems because it would just be raised up three inches and angles wouldn't change at all.. All I have is rubber shift boots, they say invert the lower boot, but IDK what the heck they're talking about..
Old Jul 28, 2008 | 02:21 PM
  #33
Well why would you need to extend your shifters if you aren't lifting your body off the frame?
Old Jul 28, 2008 | 02:57 PM
  #34
nevermind, I was thinking about moving (hate it) and what I would like to do with my truck (bl and dt lifts). sorry to interrupt haha.
Old Jul 28, 2008 | 03:05 PM
  #35
Jay351's Avatar
Well, its pretty much impossible to keep the shifter from warping a little during the process of cutting and welding them back together. A little adjusting will probibly be needed in order to be able to hit all the gears.
Depending on the model of your truck you will have 2-3 boots covering your shifters. I removed the SR5 vinyl cover and it exposed the black rubber boot. I just pushed that down so it was an inverted cone. That gave just enough clearance to hit 4th and reverse with no issues.
4crawler.com has some pictures/info about it Took 5 mins, be carefull of the staples in the boots though, I got a nasty cut from one....
Old Jul 28, 2008 | 06:13 PM
  #36
My shifter only has two boots, one under the black rubber one, and then the top rubber one, I don't have a leather one on top of that.. I hope I don't gotta invert it or its gonna look hella gay...
Old Jul 28, 2008 | 06:38 PM
  #37
Jay351's Avatar
You could also drill new holes and move the whole boot assembly back a half inch or so. Or get some SR5 stuff
Old Jul 28, 2008 | 09:06 PM
  #38
Haha Right, I doubt I'm gonna find the SR5 shifter boots any time soon.. Anyone got some?
theduck21
Sep 10, 2015 07:01 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
Cebby
Nov 19, 2008 08:11 PM
ElwayLite
Aug 24, 2004 04:23 AM
