3vze Valve lash
Old Feb 28, 2014 | 11:21 AM
alopez620's Avatar
3vze Valve lash
Hi I have a 94 3vze i was wondering if you could set valve lash with the heads off the engine. and if so do i have to recheck valve lash after i remove the cam to put the heads on then reinstall the cam.
Old Feb 28, 2014 | 11:31 AM
james92toy's Avatar
When heads are on the bench put cam in just like it was in the truck to set valve lash. It will be the same when you put heads back on motor.
Old Feb 28, 2014 | 11:54 AM
Sturmcrow's Avatar
On a lot of engines you should do the valve lash on the motor, but that it because you set it hot. The 3VZE is set cold, so you are good to go.
Old Feb 28, 2014 | 11:57 AM
alopez620's Avatar
Thx for the info. exactly what I wanted to hear.
foampile
Dec 18, 2022 01:29 PM
JHalcyonM
Mar 6, 2019 08:37 AM
ManzDaKlown24
Aug 22, 2015 10:25 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
