3vze VAFM help....
Old Apr 21, 2005 | 07:56 AM
Faded's Avatar
BY,
Thanks for the reply. I think my stock VAFM might be on the way out so I might have to look for a 7M replacement. Are they the same on both the 7MGE and the 7MGTE? Or do you want the one off of just the GE...
I'll keep an eye out for a future post from you if you find the time, that would be great.
Just curious, what A/F meter/sensor are you using?
Thanks again,
Andrew
Old Apr 21, 2005 | 10:31 AM
Cebby's Avatar
Originally Posted by Faded
BY,
You want the GE model. The GTE model isn't compatible.
Old Apr 21, 2005 | 11:50 AM
Faded's Avatar
Mike, thank you for the confirmation. I've been reading a little on your swap and I'm really looking forward to hearing more from you on that front, it sounds killer! Thanks again.
Old Jun 2, 2005 | 05:28 PM
dlbrunner's Avatar
Bumpin, Any progress?
Old Jun 2, 2005 | 06:49 PM
  #25
Bumpin' Yota's Avatar
Cut and welded up the 3" mandrel bent U pipe, just have to put a second weld line in, put bungs in, tapand thread, and install...and watch AF gauge...
Old Jul 29, 2007 | 03:16 PM
  #26
gwhayduke's Avatar
Hey Bumpin...Could you measure the size of the vane opening on the 7MGE AFM? I wanna check something out.
Also, did you ever get it to work?
Yeah, I know I'm blowing the dust off this one.
Old Jul 29, 2007 | 09:35 PM
  #27
Sure thing I just have to dig it up after work tomorrow.
I never got it to do much other than juuuuust barely idle and to get it to do that I had to set it so the engine was running 'UBER rich!
Old Mar 25, 2009 | 01:34 PM
  #28
Nashman00's Avatar
all right stop right were you are or you will be very sad person
the 7mge afm is to big for the slow 6 you will lean out and kill your motor
if you do the swap you have to put bigger injectors in or up fuel pressure and use safc(fuel computer) of some sort
drilling a hole in the tube and then monkey ***ing it with fuel computer again is stupid as hell every time you play with fuel you timing gets moved around and you have to mess with it allot pingy pingy bang bang
the only good way of doing this is convert your truck to speed density/map
http://www.maftpro.com/tproinfo.shtml
i am toying with the idea right now as well cause i need some more power out of this slow 6
Old Jun 5, 2009 | 11:16 AM
  #29
Nashman00's Avatar
well i got the 7mge one to work but i used a wide band to tune it to work but stright swap is not a good idea it will run to lean
Old Sep 1, 2010 | 12:26 PM
  #30
BMcEL's Avatar
Old thread I know...but did you notice any increase in performance? If so, where in the powerband? I've been reading up on these for some time now but haven't been able to find any definitive answers as far as power goes. At this point a simple yes it helped or no it didn't would be enough for me. Thanks in advance!
Old Oct 11, 2010 | 06:24 AM
  #31
woodsguy's Avatar
so if im just looking for a little more power i should just stick to an ISR mod? cause i dont have a lot of time or money because of school. and reading this thread it seems like there is a lot involved with this correct?
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
