3VZE speed
Old Dec 2, 2011 | 09:29 PM
bmcghie's Avatar
I believe redline for the 3vze is 5750. Peak HP is 4800, peak torque is 3400.
Something to think about when pulling out to pass. Only got 150 ponies at the best of times!
Old Dec 2, 2011 | 11:08 PM
bob200587's Avatar
Nothing wrong with cruising at 3000 or above.
Old Dec 2, 2011 | 11:32 PM
92Yoda's Avatar
My 4runner goes 110km/h at 3000rpm with 31s, not sure of my gear ratio, but the fastest ive ever had it was at 170km/h. Needless to say it wasnt safe at those speeds hahaha but she did it
Old Dec 3, 2011 | 10:42 AM
astynx's Avatar
Originally Posted by vasinvictor
My 92 with 4.88s and 31s does 3250 on the freeway 5 hours at a time. After having several of these motors, I can say they are most efficient around 2700-3000 RPMs. Also, my redline is at almost 5500 RPM. 3400 is nothing. With 4.56 gear set, what you need is bigger tires if you want to lower your RPMs, however you can expect a lot of shifting between OD and 4 if your lower your RPMs too much more.
The tires pictured in your album, are they the 33 x 12.50 mentioned in your sig?. I have 4.88's v-6 at and 31.0 x 10.50 came with vehicle from the factory. I 'm thinking about 33x 10.50's someday. Thanks
Old Dec 3, 2011 | 09:09 PM
  #25
adamthedroog's Avatar
I've come to realize that my dad put a smaller sized tire on it. We haven't recalibrated the speedometer and it reads seventy at three thousand. I assume that means that if it had the right size tire it would be going that speed?
Old Dec 3, 2011 | 09:17 PM
  #26
ThatGuy1295's Avatar
Gear Ratio Calc
Old Dec 3, 2011 | 09:18 PM
  #27
RRogers's Avatar
Correct. If he put smaller tires on, then you are not going as fast as your speedometer says you are.
Old Dec 4, 2011 | 04:30 PM
  #28
Ah-ha. Well, that's simple enough. I know what I want for Christmas!
jashoeuh
Nov 18, 2024 08:08 AM
Flossy
Aug 5, 2015 05:14 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
