3vze power loss after warming up
Old Oct 17, 2015 | 06:52 PM
jsjensen73's Avatar
I have a 91 runner with the 3vze. It starts up fine and runs ok for about 10 miles and then it losses power and has intermittent misfire/stumbling. I changed the TPS thinking that might be it. didn't change. Today I disconnected the O2 sensor and it ran fine, other then throwing a CEL. Any ideas as to why it runs better disconnected? There were no previous error codes.
Old Oct 18, 2015 | 08:54 AM
Jrose's Avatar
that is strange. Maybe you have a faulty O2 sensor and it's sending a bad signal. Have you tried replacing it to see if that fixes the problem?
Old Oct 18, 2015 | 09:08 AM
jsjensen73's Avatar
That's what i was going to do next, but thought it might be running lean with the O2 sensor. Causing the power loss and surging. Just looking for thoughts before throwing money at it.
Old Oct 18, 2015 | 01:10 PM
dbd6604's Avatar
You didn't have a CEL before you disconnected the 02 sensor?
Old Oct 18, 2015 | 05:21 PM
jsjensen73's Avatar
nope, jumped it anyway to be sure, but nothing before. Was driving down the road a couple months back and lost power. Could stay in 5th on flat ground. It was mostly in the midrange and the tps didn't read in spec so i swapped it, but no change.
Old Oct 18, 2015 | 08:07 PM
dbd6604's Avatar
This is kind of what I was thinking. Sounds like you're getting a lean condition that is causing the stumbling/misfiring, so when you unplug the 02 sensor, the engine goes into safe mode and throws extra fuel into the mix, causing the engine to run better. Clogged/dirty fuel injectors or a dying fuel pump possibly?
Keep in mind I'm no expert on the 3VZE, but I'm working on it.
Old Oct 19, 2015 | 06:18 AM
jsjensen73's Avatar
Yeah, its been an education this last year
mick.j.becker
13
Nov 1, 2015 09:49 AM
Longbed 90
Oct 19, 2015 11:05 AM
djohnson13
Sep 4, 2015 12:35 PM
toyotruggie
Sep 3, 2015 05:06 PM
sniper34639
Aug 31, 2015 07:56 AM
