3vze performance
Old Apr 30, 2007 | 07:26 AM
  #61
chimmike's Avatar
Originally Posted by yotawheelin95
what about boring the 3.0 out? anybody know of this?
really boring it out will only help so much, and I'm not sure how the cylinder clearance is.
The best thing for this motor would be to stroke it, we definitely need the torque down low and in the midrange.
Regardless, I just want to keep my 3.0 alive. It does fine for me with 5.29's on the trail, and if I want more trail grunt I'll get 5.71s. lol.
Old May 16, 2007 | 09:14 PM
  #62
displacedAlaskan's Avatar
Originally Posted by shoes138
what the hell can i get jacobs ignition stuff?
Try
However, I found my system on Ebay used for $100 on a $450 system. I like my setup. I did have to build my own coil wires though, and if you use an aftermarket ignition system you need to upgrade your spark plug wires to lower resistance wires. Accel makes good low resistance wires and also Magnecor wires worked especially well on my Subaru Impreza.
Old May 16, 2007 | 10:49 PM
  #63
Jay351's Avatar
I will let everyone know about weasy's cams, I set up a date at the end of the month, I am getting just the cams and some other parts (not performance adding).
Old May 17, 2007 | 10:34 AM
  #64
What do you mean by "stroke it"?
Old May 17, 2007 | 11:41 AM
  #65
dcg9381's Avatar
Increase the displacement (size) of the motor by making the crank have longer throws. It usually requires custom pistons, which end up making things pretty expensive.
Old Jan 25, 2022 | 01:10 PM
  #66
pplusent's Avatar
Stay with the 3.0. 3.4
3.4 is much more complicated. Buy the cheap headers on eBay. Full exhaust system $156. Build your own engine. Bore and deck heads and block, install head studs with MLS head gaskets. Regrind cam, and a stand alone engine controller that allows you to use a 3 inch full flow MAF sensor eleveating the air flow issue and tunable fuel curves. 200 hp plus.
Kamaloha
Oct 16, 2015 05:13 PM
Iceman4193
Oct 16, 2015 10:50 AM
kbpickens
Oct 2, 2015 03:37 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
oldblue
Sep 28, 2015 04:07 PM
