3VZE Oil in Water
Old Nov 11, 2021 | 11:54 AM
Tech2123's Avatar
3VZE Oil in Water
I have a 1990 3VZE 4 Runner, I have OIL in the WATER!
There us NO white Smoke out of tail pipe, NO water in Engine Oil, Dip stick clean, Oil cap Clean.
Runs great, decent power.
Automatic Trans (Cooler is currently Bypassed)(Not daily Driving it)
Oil Cooler (currently bypassed)
Flush system 20 + times
Still Oil in water, seems better though, but there.
Head gasket? Cracked Block?
Old Nov 11, 2021 | 12:23 PM
MaK92-4RnR's Avatar
Probably a cracked headgasket. Do a dye test on the radiator and see.
Old Nov 11, 2021 | 12:58 PM
scope103's Avatar
A dye test is a good idea, but won't necessarily help. Tech2123 has oil in the coolant. The dye test checks for combustion products (specifically, CO2) in the coolant. You can have one without the other; just depends on where the headgasket has failed.
Old Nov 11, 2021 | 01:46 PM
MaK92-4RnR's Avatar
Still possible for CO2 to be making it into the radiator. Even the smallest amount can cause the dye to react.
Old Nov 11, 2021 | 02:28 PM
scope103's Avatar
Sure, that's always possible. But if the test comes back "negative," what does that tell you? It certainly does not mean that the head gasket is okay.
Old Nov 12, 2021 | 06:16 AM
MaK92-4RnR's Avatar
Oil in the coolant is good for electrolytes. Send it.
Old Nov 12, 2021 | 06:27 AM
COMTB's Avatar
Just an excuse to put a 5vz in it...but in all reality oil in water is never really a good thing. Sounds like head gasket to me as well, especially with the oil cooler bypassed.
Sikes_94Yota
Jul 22, 2013 07:42 PM
ugabulldog
Aug 1, 2010 07:11 AM
81redbluffyota
Jan 19, 2008 12:35 AM
yota truck
Nov 30, 2005 11:53 PM
hektikwon
10
Nov 17, 2005 06:48 PM
