3vze How many miles?
Old Oct 24, 2006 | 01:08 PM
  #61
JHRRLD's Avatar
393,000 on the clock when I sold my 90 4runner. HG replaced at 175,000 miles.
Old Oct 24, 2006 | 08:02 PM
  #62
mpavolka's Avatar
My 90' 4Runner had 240,000 when I sold it. It never had any engine work besides timing belt(s). It ran great but the automatic tranny was on its way out.
Old Oct 24, 2006 | 09:26 PM
  #63
pennywize's Avatar
just turnd 185,000 miles. head gasket recall done at approx 65,000. timing belt and water pump done by me at approx 145,000. no major problems. i use mostly castrol 20-50 i change it when i remember to. which reminds me i think i need to, it's been a while.
Old Oct 24, 2006 | 10:54 PM
  #64
CyMoN's Avatar
162k miles and no problems so far T/C was replaced about 7000 miles ago small leak on valve cover.
about to do a oil change going to try the castrol GTX also need to change plugs &wires and 02 sensor soon.
Old Feb 16, 2010 | 08:54 AM
  #65
Seanwain's Avatar
91 Pickup 4x4 318,000 miles no major motor work a/c blows cold original Head gaskets. rebuilt rear axle, new leaf springs, rebuilt front end control arm bushings, ball joints, wheel bearings, tie rods at 310,000 has several oil leaks needs new timing belt, dealer pushing me to do the HG recall said it would save $300.00 on the timing belt.
Old Feb 16, 2010 | 09:27 AM
  #66
mt_goat's Avatar
Wow, congratulations! Did they say how much longer the HG recall was going to last? I thought they stopped that already.
Old Feb 16, 2010 | 09:41 AM
  #67
Seanwain's Avatar
They did not I brought the truck in for the steering link recall and the service advisor called me about the HG recall, I have always be a proponent of the "if it aint broke don’t fix it " saying but I am thinking of taking advantage of the discount in labor. My main concern is what problems they might uncover when they pull the heads off.
Old Feb 27, 2010 | 10:39 AM
  #68
CyMoN's Avatar
wow 4year old thread brought back from the dead I am now at 180,281
Old Jun 30, 2010 | 07:20 AM
  #69
barthmonster's Avatar
Bought a '91 4runner for my daughter and it 'appears' to have a head-gasket problem. The local dealer verified that this job has been 'done' on this truck. I'm so frustrated I could spit !
She overheats at the drop of a hat with a new radiator and a new thermostat (drilled at 12-clock to pass air) and it gets hot easy. Also, when completely cooled down the next morning, removing the radiator cap caused some pressurized gas to escape. This doesn't seem normal to me. could the dealer who 'fixed' this on recall have just thrown in more of the 'bad' gaskets ??
Which gaskets do I need when doing this job ??? Rock ? I want the best in fact I'd like solid copper like a racer uses, but I havn't found any...
Thanks,
Brad
Old Nov 9, 2010 | 07:36 PM
  #70
jiffylubej42's Avatar
176 n change oil changed every 3000 from new mexico women owned /pampered then drove from nm to wisconsin in between started missing bad n she sold to me very clean for 100$ havent fixed it yet think burned valve not sure as antifreze stays same as well as oil plus very recent tune up by me all new spark plugs wire rotor cap.plus fuel pump went out n i matched up chevy pump
Old Nov 9, 2010 | 07:42 PM
  #71
quick question about the hg recall how would i find out if mine is exceptable/still up for grabs if time hasnt run out ??etc.... sorry to redirect ne 1 with input please give me direction ty
Old Nov 9, 2010 | 07:50 PM
  #72
MudHippy's Avatar
Oh boy! Here we go fellas!
Just to get it out of the way, and onto the record, mine went 218,000 miles before blowing the original head gasket. No other major engine work 'till around 224,000miles when I had to tear it down to replace a cracked piston. Nothing since with around 230,000 miles now. And such is not as uncommon as is popularly believed.
Do I ever have a thread for you on the 22RE vs. 3VZE reliability debate. One of my finest hours...
Enjoy!
https://www.yotatech.com/forums/f116...-valve-222710/
Old Nov 9, 2010 | 08:25 PM
  #73
hippy when ever i see your post i cant help but being glued to the screen to read every detail u r truely pasoniate n well informed as far as i can tell....as r many other here at yt
Old Nov 10, 2010 | 04:04 AM
  #74
phildelfino's Avatar
1988 4Runner, over 234,xxx miles. Don't know how many P.O. there were on this vehicle. Does not qualify for HG recall (it's got the good ones). Owned it over 3 yrs now and have an O2 sensor into it along with a recent (this summer) water pump, fuel pump, timing belt replacement. Other than a tune up every year, timing light and timely oil changes, nothing major to this 3.0L motor.
Old Nov 10, 2010 | 05:36 AM
  #75
vasinvictor's Avatar
Since we are indeed posting to this 7-8 year old thread and I missed it on the first go-round... My previous 95 t4r v6 had 183k with on 1 timing belt/water pump before I wrecked it. My current 3vze has 204k on it, and only ever timing belts and valve adjustment. Gets 15-16 mpg regularly on 87 gas. This is my 2nd 3vze and I will purchase another. Both have had head gaskets done, 1 under warranty. They are the most reliable motor I've ever had the pleasure of owning. Not so pleasurable to work on in the rare case it's necessary, but I know my way around by now.
Old Nov 10, 2010 | 05:13 PM
  #76
zhack44's Avatar
164,000 on my 93 pickup with the 3vz. new timing belt at 80K. otherwise runs like a champ
Old Nov 10, 2010 | 06:03 PM
  #77
MudHippy's Avatar
From what I understand you need to contact a dealership and give them the VIN. They'll have a record of any recalls having been done or not. And if they haven't they'll tell you whether they still can be.
Wow, that's very flattering. How kind of you to say that. Thanks!
I'm proud to have established such a following, or atleast gained a follower, here. Maybe I really can make a difference? Love me, or hate me though? That's up to each individual to choose. Either way, there's no stopping me now. I'm on a roll!
Old Nov 15, 2010 | 11:33 AM
  #78
norcal707's Avatar
205k just finish replacing the headgasket. runs ok, I am getting 15 mph on the highway which is making me think of selling it.
Old Nov 16, 2010 | 06:49 PM
  #79
95ToyotaPU007's Avatar
3vze
362,543 miles on my 3vze. Too bad I don't drive it as often as I used to.
Old Nov 16, 2010 | 07:15 PM
  #80
blueyota4x4's Avatar
260,700 miles on my 93 pickup. head gasket replaced due to recall
