3vze Help
Old Aug 14, 2009 | 11:04 AM
nygaard208's Avatar
yeah but i got some typical headgasket leaks that need to be tended too anyways so i will do it when i do that
Old Aug 14, 2009 | 12:08 PM
nygaard208's Avatar
anybody else think that a short to my knock sensor might give me that strange knock...dont get what other role it plays if it has nothing to do with its name?
Old Aug 14, 2009 | 12:12 PM
runethechamp's Avatar
Sorry to say that your symptoms are exactly the same as the ones I had when one of my rod bearings went out. For a long time I just got the knocking sound at certain rpms, and after a while it got worse and worse, and the oil pressure was certainly on the low side. Hope it isn't something that bad for you, and good luck in any case.
I bet the sputtering has to do with your knock sensor (wire) though.
Old Aug 14, 2009 | 12:33 PM
nygaard208's Avatar
yeah that deff sucks. im in the army so rebuild projects are hard to find time to do
Old Aug 20, 2009 | 10:47 AM
  #25
nygaard208's Avatar
so what would you guys say if i told you the knock isnt rpm related? driving it more i have noticed that it only makes the sound when i hardly touch the gas. truck sputters so when i press on the gas just slightly it doesnt increase rpm quickly but the knock goes away...
Old Aug 20, 2009 | 10:52 AM
  #26
nygaard208's Avatar
as long as i stay half throttle taking off there is no knock. its when i try to crusise by barely touching the gas to not excellerate or decellerate
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
