3vze FPR
Old Feb 11, 2013 | 02:33 PM
Cpasour's Avatar
3vze FPR
I have a 92 3vze that is missing, bucking, and some almost dies I can try and rev it up a few times and sometimes it will go. I pulled the vaccuam lines off the fuel pressure regulator and the big line has gas in it I was trying to find out if it is bad and could this be causing my problems
Old Feb 11, 2013 | 03:55 PM
hambob's Avatar
Sure is a strong possibility. if there's gas in the vacuum line than the internal diaphragm is busted and fuel is being sucked into your intake. Not to mention that the FPR isn't doing its job properly.
Old Feb 11, 2013 | 04:11 PM
Cpasour's Avatar
Ok there is no gas in the small vacuum on top but the larger vacuum line on the side so there should be no gas in either
Old Feb 11, 2013 | 04:45 PM
MudHippy's Avatar
Wrong(well... half-right). The small line at the top is a vacuum line(to the FPU VSV). The larger line on the side is the fuel return hose(to the fuel tank).
http://personal.utulsa.edu/~nathan-b...89fuelpres.pdf
http://personal.utulsa.edu/~nathan-b...ne/99fuelp.pdf
Old Feb 11, 2013 | 06:15 PM
Cpasour's Avatar
Ok thanks I wasn't sure
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
