3vze code 71
Old Jul 11, 2019 | 08:01 AM
mike250's Avatar
3vze code 71
So i was driving my truck and and it just died all of a sudden. I can turn it on but it only runs for about 2 seconds. If i mash the gas pedal i can get it to run longer but it still will eventually shut off. I checked the cel and got 7 blinks then 1 blink. The cel was on for a quite some time a while ago but i thought i had checked it and thought it had to do with a bad catalytic converter. but now it is giving me a different code. i don't know maybe i misread the code, i have no idea. it would store two codes at once right? i dont know, but anyways fsm says it is a EGR System Malfunction and gives me these probable causes. if you were in my shoes where would you start? -thanks
• Open in EGR gas temp.
sensor circuit
• Open in VSV circuit for EGR
• EGR vacuum hose discon–
nected, valve stuck
• Clogged in EGR gas passage
• ECM
Old Jul 11, 2019 | 12:20 PM
Dom91's Avatar
I'd start with vaccum leaks
Old Jul 11, 2019 | 01:04 PM
mike250's Avatar
ok so i unplugged the throttle position sensor and vafm and the truck started and idled fine. but as soon as i plug either of those back in it dies.
Old Jul 11, 2019 | 01:23 PM
Dom91's Avatar
What if only one is unplugged?
Old Jul 11, 2019 | 01:43 PM
mike250's Avatar
it only runs with both unplugged. if i plug in the vafm it will die. if i plug in the tps it will die. however i took cover off the vafm and increasingly turned the dial thing counter clockwise until i was able to plug the vafm and tps back in and have it continue running. i just have to hold the dial in a certain position to keep it running, as soon as i let go it dies.
22REFORME
Feb 28, 2020 07:23 PM
Viet0ne
Mar 14, 2019 08:55 PM
mytoyota86
Oct 4, 2011 05:43 PM
89whitetoyota
Jul 19, 2010 08:51 AM
mmunoa
May 2, 2010 02:31 PM
