3VZ-E rev limiter?
Old Jan 8, 2008 | 04:31 PM
MudHippy's Avatar
Originally Posted by Mr_Martinez1982
not sure what the exact RPM limit is but the miles per hour is like 105
not sure mechanics should be doin that either. I do it, but on my car and my car only.
Originally Posted by yotaman90
Yeah I'm sure that I didn't hit the governor. It was revved at a standstill in the autoshop
Sorry, I forgot to quote him on it. I believe you, still wondering about Mr_Martinez. What's he sayin' exactly? His truck gets goin' like 105 miles per hour when the rpms top out, or that he found the governor/miles per hour limiter around 105?
Old Jan 8, 2008 | 04:39 PM
yotaman90's Avatar
I'm not sure, I wouldn't take mine over 80, starts to float like a boat........
Old Jan 8, 2008 | 04:48 PM
ernest t bass's Avatar
stock horsepower peak is 4800 so that would be a good redline.
i have heard that reving an engine in neutral (without a load was BAD)
my 3.0 seems to like to rev. it feels out of sorts at lower rpms then clears out at what feels like the torque peak, 3400
i have the cheap guage cluster so its just a guess.
it seems to me that the biggest problem with the 3.0 is a torque peak too high, 3400 rpm.
Old Jan 8, 2008 | 06:31 PM
Bumpin' Yota's Avatar
This thread makes me laugh.
My 3vze has been beat to hell and back. 5800rpm shifts every day of its 10 span with me. She's seen 285,000 miles. No issues other than a popped HG a while back. Still has plenty of power and still sees 4500-5500 rpm when I drive her. I have calmed down slightly on my yota since my GTO appeases my need for speed. But comeon people the 3vze was designed to rev!! Just adhere to the severe duty maintainance schedule and youll be fine.
btw, you want a high rpm torque peak, becuase you want area under the curve. A higher torque peak means more hp, since afterall the hp is a calculated number based off tq....
The 3vze needs tq down low, in mid range, and up top. Hell it needs tq everywhere.
Oh and I still get 20mpg on highway.
Old Jan 9, 2008 | 07:37 AM
  #25
yotaman90's Avatar
The 3vze needs tq down low, in mid range, and up top. Hell it needs tq everywhere. Oh and I still get 20mpg on highway.
Well thats you, I can't afford to have mine break. With only 84000 miles it shouldn't, but I'm not taking any chances, especially with an old timing belt
Old Jan 9, 2008 | 09:44 AM
  #26
Jay351's Avatar
You saying you're running the original t-belt? I hope not!
Old Jan 9, 2008 | 10:11 AM
  #27
yotaman90's Avatar
To tell you the truth, I know that it's been replaced, but it was maybe 5 years ago at least and I don't know at what mileage. Another thing is that it was installed by a chevy dealer (don't ask me why, it wasn't my truck then) because a bearing seized on something (I think in an idler pulley). Thats why I'm kind of skeptical about the timing belt
Old Jan 9, 2008 | 12:46 PM
  #28
Redeyejedi's Avatar
HP=Torque @ 5252 RPM
i redlined my truck once, by accident. i dont think she liked it, so i didnt do it again.
and bumpin, how'd the 3.0 satisfy your need for speed b4 the gto? speed is certainly not one of my truck's attributes.
Old Jan 10, 2008 | 07:24 AM
  #29
yotaman90's Avatar
I second that!
Old Jan 10, 2008 | 08:18 PM
  #30
lol, other than beating up on Prius' and Xb's it really did not satisfy that need. However it made up for that deficiency by being able to go whereever I really wanted to go and by having a bitchen stereo!
the Goat fulfills that need to go fast VERY well.
10-4, Im just saying revving it wont "hurt" it persay. Shorten life expecancy sure, but its still a toyota!
BTW swapping the T-belt is easy. Jump in there and have some fun! Oh and the 3vze is a non-interferance engine, so if the timing belt broke on you, everthing should be ok.
Old Jan 10, 2008 | 08:38 PM
  #31
Jay351's Avatar
Yes, if the t-belt breaks the only bad thing is you will need a tow home
And for the record, I hardly ever take my engine over 3,500rpm except for the occaisional full throttle run. I can't afford to keep pumpin fuel into it
Old Jan 10, 2008 | 08:47 PM
  #32
CoedNaked's Avatar
Nothing stops this truck between 3000-4000 RPM's, especially aroun 3300-3600 RPM's, but I haven't taken it over 5000 RPM's (no point) and I rev it to about 4500 every so often but generally like to keep it below say 3000 when driving reguarly (I usually shift between 2600-3000 depending on the gear). A nice steady highway drive at about 70 MPH at around 3000 RPM's seems to help the engine clean itself out a little bit. I don't know if it's just me or the fact that everything gets up to operating temperature and all that, but my truck seems to run a little better after a nice highway drive.
Old Jan 10, 2008 | 08:56 PM
  #33
Greg_Canada's Avatar
rev limit is 5750 rpm just like every truck engine toyota has put out 79-04.
5vzfe, 22re, 22rte, 3vze, 2rz, 3rz, 1gr-fe, all have the same rev limit.
Old Jan 10, 2008 | 09:11 PM
  #34
Jay351's Avatar
Originally Posted by CoedNaked
Nothing stops this truck between 3000-4000 RPM's, especially aroun 3300-3600 RPM's, but I haven't taken it over 5000 RPM's (no point) and I rev it to about 4500 every so often but generally like to keep it below say 3000 when driving reguarly (I usually shift between 2600-3000 depending on the gear). A nice steady highway drive at about 70 miles per hour at around 3000 RPM's seems to help the engine clean itself out a little bit. I don't know if it's just me or the fact that everything gets up to operating temperature and all that, but my truck seems to run a little better after a nice highway drive.
Mine tends to idle at 1100-1200rpm after a nice hwy drive
Need to get that replacment o2 sensor in there soon!
I have gone past there numerous times.....
Old Jan 11, 2008 | 05:32 AM
  #35
ditto - ive had my 3vze DEEP into the 6k rpm region without hitting any kind of limiter. (Accidentially)
The 5vzfe is redlined at 5200rpm vs my 3vze's redline of 5800.
Old Jan 11, 2008 | 07:24 AM
  #36
yotaman90's Avatar
Thats usually how I drive mine
Old Jan 11, 2008 | 08:27 AM
  #37
my 3.4 and my 3.0 both have 5500 rpm "redline's" and i've hit the rev "limit" at 5750 as well.
ALTHOUGH, with the 3.0, i have miss shifted and gone over 6 grand.... (3.4 is an auto)
Old Jan 11, 2008 | 08:39 AM
  #38
bigtrucknwheels's Avatar
no clue what it was set at, damn the DLX cluster, but I hit the revv limiter for the first time ever in my truck the other night. In an auto. The engine screams at those RPM's, but oddly, I felt sure that it wouldn't blow. It seems to like to rev when you put the gas to it. It felt solid with pretty decent output @ rev limits. She drank gas pretty quick though. I had it up near the top end for about 15 minutes, engine temp gauge moved to where it normally is during the summer, so no over heating. The truck stretches well...
Yeay for muddy fields! I'll post pics of the mud on my cleaned the truck thread, haha.
Old Jan 11, 2008 | 11:08 AM
  #39
Jay351's Avatar
The funny thing is, around 3-4k the 3.0 sounds like its gonna blow up, but after around 4500rpm it all smooths out.
Old Jan 11, 2008 | 12:05 PM
  #40
Volcom's Avatar
Ever heard of floating a valve?? Revving an engine with no load on it is very bad for the engine. They aren't made to be revved that high with no load.
https://www.yotatech.com/forums/f2/5...ng-soon-77718/
"A high-rpm engine condition in which the valve lifters lose contact with the cam lobes because the valve springs are not strong enough to overcome the momentum of the various valve train components. The onset of valve float prevents higher-rpm operation. Extended periods of valve float will damage the valve train."
