3rd member question - 81 into 87 front?
Hi gurus,
Will a 3rd member from a 1981 Toy PU work correctly, with no mods, in a stock 1987 4Runner?
Will the 3rd member from the rear axle of that '81 fit?
This seems to say "no way, dude"
http://home.4x4wire.com/erik/diffs/#front
If I'm going from 4 cylinder to turbo truck, do I need to worry about the pinion strength? I read somewhere that there was a difference.
Thanks!
Eric
Thanks!
Eric
Are you asking if the front 3rd from a 81 will fit in the front of an 87? The answer is no. The 87 front 3rd is 7.5 IFS. The 81 front should be a straight axle (just like the rear) and that is a 8in. Check out the FAQ or search.
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
