35's no lift
Old Mar 7, 2012 | 07:27 AM
  #61
wii_tarded's Avatar
I did a BL to clear a 3.4 swap. Side effects: 1.) easier to get the trans. mounted 2.) replacing rear shocks and springs was a lot easier 3.) now I have more room to flex the rear once I get 33's. 4.) I like the stance now.
Down side: 1.) aftermarket bumpers will not fit without modification 2.) wife complains on height 3.) modded my shifters for the BL, didn't get it done right, and now shifter's are jacked 4.) you will tear the rubber boot around the shifters when you do a lift (or at least I did)
Old Mar 7, 2012 | 10:00 AM
  #62
cman1's Avatar
AND WII Tarded, when it s cold my shifter pops out of gear because the shifter boot is so stiff.i had to unscrew it from the floor so it free floats.
Old Mar 7, 2012 | 10:32 AM
  #63
Stuwy123's Avatar
So far I see one truck with 35's and no lift.
It looks like it rubs like mad!
A local guy here is running 35's with no lift on his 4runner.
To give you an idea of how much he cut out:
Stock:
Cut/hammer (fender removed for access):
A couple patches:
Finished fender well tubbing:
Old Mar 7, 2012 | 10:44 AM
  #64
Cyberman's Avatar
How about 37s and no lift...
Not mine. Still running IFS, dual cases w/4.7s 37" Pitbull Rockers.
Old Mar 7, 2012 | 11:43 AM
  #65
cblackard's Avatar
deleted
Old Mar 7, 2012 | 11:46 AM
  #66
ThatGuy1295's Avatar
BL = less top heavy than suspension lift (only body weight is raised, not frame, engine, trans, etc...)
Ya but only one of those actually does something.
Old Mar 7, 2012 | 01:02 PM
  #67
wii_tarded's Avatar
That bumper is sexy, wonder how it'd look on my rig...
Old Mar 7, 2012 | 01:15 PM
  #68
On the other hand some combo of body lift, hammer love, t bar adjustment, BJ spacers, and sawzall might make this work.
X2 Alittle of everything. Maybe 1 or 2'' BL at most and some cutting ect...
Just don't want to see another 3'' body lift guy with no other mods braggin about how his truck is magically more capable because HIS SEAT IS HIGHER UP, but he left his frame sitting on the ground.
And yes the point of any lift is to fit bigger tires for more real clearance. But a sawsall does that. And without sacrificing stability. Theres no reseon to jack the body 3'' in the air besides trying to look cool.
Old Mar 7, 2012 | 01:23 PM
  #69
vital22re's Avatar
totally a bro
I did a 1" BL for a 3.4 swap and for sliders so I wouldn't have to chop the cab.
Old Mar 7, 2012 | 04:37 PM
  #70
rattlewagon's Avatar
Im still stock on 35s. It rubs a little, so what. Its not hurting anything. Just grind everything smooth. Wheels great, and is super stable.
Old Mar 7, 2012 | 09:36 PM
  #71
Seee!! No body lift....weird. How are you doing that? :sarcasm:
Old Mar 8, 2012 | 08:18 AM
  #72
monsterenergytoy's Avatar
I have a 4 inch suspension lift and 2 inch body lift and with 35 it works great other than they rub a little on the front valance but I love the setup it looks really good
Old Mar 8, 2012 | 08:36 AM
  #73
Surprised you even put a BL on with a 4inch suspension you can clear 35's no prob.
These are 33's with no lift, and chopped fenders.
Old Mar 8, 2012 | 08:39 AM
  #74
My 35's were 14.5 wide though and it rubbed when i turned
Old Mar 8, 2012 | 08:42 AM
  #75
Did you adjust your lower A-arms forward?
Old Mar 8, 2012 | 08:45 AM
  #76
Not sure my uncle did the lift when the truck was his but I just have 33's now
Old Mar 8, 2012 | 08:49 AM
  #77
Old Mar 8, 2012 | 09:10 AM
  #78
Haha I'm not exactly sure how to put up a pic
Old Mar 8, 2012 | 09:16 AM
  #79
drmix's Avatar
Set up a photobucket and upload your pics there
Old Mar 9, 2012 | 06:13 PM
  #80
BeaterToyota's Avatar
I never wheeled it this way, but I did drive it around town for a couple of days before my SAS... 36" TSLs with about a 1" lift shackle in the rear and bj spacers up front. Some cutting and hammering could have made it work.
For comparison, 37" MT/Rs with SAS using 3" trail gear junk:
