3.0 vs 3.4 trans 5spd..
Old Oct 6, 2010 | 08:17 AM
808-3VZE's Avatar
Whats the difference between the two transmissions? I reasearched that you use the 3.0 trans for the 3.4 swap. Lmk. Thanks fo da info!!!
Old Oct 6, 2010 | 09:29 AM
just call me smithy's Avatar
the diffrence between the two other then flywheel and clutch size ( note that the two share the same spline cout thus allowing you to use ether the 3.0 clutch or the 3.4), is the drop of the transfer-case, in a 89-95 5speed the drop is on the passenger side on a 96+ its on the drivers side, so if you plan on keeping your rig a 4x4 you will need a 89-95 v6 5speed, you can go with the 96+ but you will need to change the drop of your frunt axle, if your looking to do an sas you could go with a dana 44 or a dana 60 ,( i think they both have a driver side drop but dont quote me on it). hope this helped
Old Oct 6, 2010 | 11:11 AM
808-3VZE's Avatar
Originally Posted by just call me smithy
the diffrence between the two other then flywheel and clutch size ( note that the two share the same spline cout thus allowing you to use ether the 3.0 clutch or the 3.4), is the drop of the transfer-case, in a 98-95 5speed the drop is on the passenger side on a 96+ its on the drivers side, so if you plan on keeping your rig a 4x4 you will need a 98-95 v6 5speed, you can go with the 96+ but you will need to change the drop of your frunt axle, if your looking to do an sas you could go with a dana 44 or a dana 60 ,( i think they both have a driver side drop but dont quote me on it). hope this helped
Ok. Does both transmissions have the transfer case built into them?
Old Oct 6, 2010 | 12:21 PM
the 5speeds are not built in to them they can be unbolted, as for the autos you need a special adapter to do dual t-cases, if thats what you mean, unfortinitly a passenger drop t-case off of a 89-95 5speed will not fit on a 96+ 5speed, ive tried.
Old Oct 6, 2010 | 01:21 PM
808-3VZE's Avatar
the 5speeds are not built in to them they can be unbolted, as for the autos you need a special adapter to do dual t-cases, if thats what you mean, unfortinitly a passenger drop t-case off of a 98-95 5speed will not fit on a 96+ 5speed, ive tried.
Cause i found a 3.0v6 5spd trans for sale. My cousin has a tacoma and he wants to do a auto to 5spd swap. So i wanted to know what trans is better 4 dat. Thanks for da help!!!
Old Oct 6, 2010 | 06:40 PM
808-3VZE's Avatar
Anybody else?
Old Oct 6, 2010 | 09:50 PM
if its a 3.4 i would do some more research, Ive herd some mixed reviews about swapping the trannys , that is without rewiring the whole motor and changing the ecu's, if its a 3.0 then you shouldn't have a problem. what motor do you have?
Old Oct 6, 2010 | 10:02 PM
vital22re's Avatar
totally a bro
the 3.4 has the slave cylinder on the driver side. The 3.0 has the slave cylinder on the passenger side.
Old Oct 6, 2010 | 10:21 PM
DeathCougar's Avatar
This cannot be done on the Tacoma due to the front diff being on the drivers side.
You have to find a 3.4L transmission. If you buy the 3.0L trans, you effectively bought yourself a 150lb paperweight.
Old Oct 6, 2010 | 10:27 PM
SpecialScottie's Avatar
What if you SAS it with a toyota axle? Then you could use the 3.0 trans right? Would it bolt in and work?
Old Oct 6, 2010 | 10:29 PM
Yes, i suppose that could be done.
I see your point and raise one more point!!! If he is just trying to swap to a 5 speed, finding a donor truck with all the correct parts would be cheaper than swapping in the wrong trans and SAS'ing the rig
Old Oct 6, 2010 | 10:49 PM
Done mean to hijack but since its a similar question I thought it would be better to ask it here than start another thread.
Would a 3.0 5 speed bolt up to a 96 4runner with a 3.4 automatic?
Old Oct 7, 2010 | 12:50 AM
808-3VZE's Avatar
Think he wants to do that.
Old Oct 7, 2010 | 12:51 AM
808-3VZE's Avatar
Yes it will
Old Oct 7, 2010 | 12:53 AM
808-3VZE's Avatar
U are correct!
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
Valvoman
Aug 8, 2015 03:52 PM
ghostmoney
Aug 6, 2015 08:40 AM
93toyoguy
Aug 2, 2015 07:41 PM
