3.0 Surging 1800-2400 rpm
Old Dec 26, 2012 | 03:59 PM
yotadude153's Avatar
Before everyone says it... yes it did search this issue multiple times....
So i got this truck with a blown clutch... had been sittin close to a year. When it first got it going i didn't really notice it but after about 500 miles i noticed it would start surging at light throttle (between maybe 1/4 and 1/2 throttle) when between 1800 and 2400 rpm. Along with clutch i did fuel filter, air filter, t-stat, all fluids, cleaned maf and the normal stuff.... Once i noticed this surging i went ahead and did the plugs, cap, rotor, wires, timing and it seemed to go away for a while but now its back again worse than ever. I've since checked plugs and timing and everything still looks brand new.
Couple notes about this problem:
If i give it more than 1/2 throttle when it starts to surge it will lessen up and if i floor it it will smooth out completely.
Seems to do it worse when cold.
Its a fast surge.. like maybe twice per second.
No sound difference... only noticeable in feel.
Runs perfect otherwise... no rough idle or sputters/misses.
Old Dec 26, 2012 | 04:06 PM
Ocell's Avatar
My money is on your TPS (throttle position sensor) needing calibrating.
Old Dec 27, 2012 | 03:32 PM
sechott's Avatar
I had a surge problem, when I burped the air pocket out of the coolant it went away. It may also be a filthy intake routing and throttle body, or TPS out of adjustment or bad, or a vacuum leak.
Old Jan 4, 2013 | 10:24 AM
i've checked vac leaks... i'll take a look at intake routing later today. can anyone point me in the direction of a good tutorial for recalibrating the tps?
Old Jan 4, 2013 | 10:35 AM
bone collector's Avatar
those are all good suggestions. i would also seafoam the vacuum lines. especially since it has been sitting a year
Old Jan 4, 2013 | 10:42 AM
hambob's Avatar
The calibration procedure in the fsm is best. The Haynes manual has it too but isn't the same as the fsm. I always go with the fsm. It involves two different feeler gauges and a multimeter iirc. I haven't seen any other tutorials out there.
Old Jan 5, 2013 | 03:01 PM
Herkdriver's Avatar
FSM has a very good description. This is also helpful:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Good luck!
Old Jan 5, 2013 | 09:29 PM
sweet thanks for the help guys. i'll keep yall updated
smthwsn357
May 1, 2024 07:28 AM
wafoogalla
Nov 2, 2016 11:02 AM
bighaydn
Aug 4, 2015 07:17 PM
Dakotaneu
Jul 27, 2015 12:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
