3.0 motor mount differnce?
Old Feb 25, 2013 | 08:25 PM
4x44runner's Avatar
I blew up my 93 runners motor so i bought another parts motor with a good block. I went to switch my motor mounts and brackets over to the other motor and this motor for the driver side doesnt have the single upper bolt hole and the passenger side doesnt have the holes in the block for the 2 upper.. What the hell do i do? custom fab the block to accommodate my motor mounts?
Old Feb 25, 2013 | 09:48 PM
JonnyBoy's Avatar
How was it mounted in the donor rig? It'd probably be a bit of a pain to drill and tap the block, so I'd just use whatever was holding it in the donor rig, unless it was something scary unsafe.
Old Feb 25, 2013 | 09:50 PM
4x44runner's Avatar
I'm not sure is the thing... It came from an 89 2wd I was told I only needed the block...
Old Feb 25, 2013 | 09:57 PM
JonnyBoy's Avatar
Not to be insulting, but have you cleaned the block up enough there to truly know that there's no threaded holes there?
I don't have any experience with the 2wd's, but I can't imagine they'd really have separate 2wd and 4wd blocks.
Old Feb 25, 2013 | 10:03 PM
4x44runner's Avatar
Yes the block has already been pressure washed and steam cleaned... The brackets don't match.. I dont get it
Old Feb 25, 2013 | 10:31 PM
Co_94_PU's Avatar
http://www.enginebuildermag.com/Arti...ta_30l_v6.aspx
This is a pretty good span of years for an application to cover, however, there is a difference in the number of bolt holes for the motor mount. Earlier ones had six, while later ones had four
Incase thats not clear, You need the mounts that match the engine year. There were lots of threads when I searched Sorry man
Old Feb 25, 2013 | 10:43 PM
4x44runner's Avatar
so now way to custom fab mine on...? maybe ill have to get creative...
Old Feb 26, 2013 | 09:45 AM
Co_94_PU's Avatar
"site:yotatech.com 3vze motor mount" Should get you started, don't forget to check out the images.
There should be atleast one thread that mentioned custom fabbed ones I don't recall the shop name for who fabbed em something with a B maybe. Yeah not alot of help sorry.
tobylab
Jan 18, 2016 07:06 PM
keithporter83
Jul 24, 2015 07:37 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
tobylab
Jul 12, 2015 12:53 PM
Coreyr384
Jul 10, 2015 11:13 AM
