3.0 knocking at idle
Old Jan 4, 2007 | 11:38 AM
NHyotski's Avatar
Hey folks, I have a 91 pickup with a factory re-installed 3.0 (the guy before me went through the official recall process) it's probably got less than 60k on it. lately it's been making a wrapping/knocking sound around idle rpm speed, both in and out of gear, above about 2000 rpm its totally normal. it reminds me of the beginning of the timing chain cover woes i had with my yota 4 cylander a few years back, but my understanding is that this has a timing belt and not a chain.
it seems to be coming from the lower regions of the block but i can't really tell, anyone got any ideas?
thanks.
Old Jan 4, 2007 | 03:12 PM
8yota9's Avatar
dose it sound like a tin can ratling around under the hood cuz i got the same prob in my 89 v6
Old Jan 4, 2007 | 07:27 PM
yota_krazy's Avatar
Drain and strain your engine oil and look for deposits. Is it a dull knock?
Old Jan 5, 2007 | 10:25 AM
NHyotski's Avatar
tried it, no deposits, on closer inspection its actually more of a tick than a knock, my hearing sucks so i needed a second opinion and they also confirmed that it is in fact a tick and not a knock.
Old Jan 5, 2007 | 03:52 PM
Silicon_70's Avatar
I'm not too familiar with V6 engines, but when was the last time your valves were adjusted?
Old Jan 5, 2007 | 04:03 PM
keithguts's Avatar
I had a proble as you do. At an idle. It almost sounded like a low tick, and then at times it would get loud, and the soft again. This turned out to be a bad injector. Injectors can sound just like a tapping valve.
Charecter1
Nov 6, 2023 10:08 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
keithporter83
Jul 18, 2015 12:37 PM
ZONAYODA
Jul 13, 2015 07:17 PM
tobylab
Jul 12, 2015 12:53 PM
