2wd speedometer gear options?
Old 06-17-2007, 06:00 PM
Rebel's Avatar
Do we have any factory or aftermarket options to correct for larger tires? Can't find much info on it. I'm looking for mechanical speedo for 91 model year. I have 235 75 15 tires and stockers, according to door sticker, 195 75 14. Thanks!!
Old 06-17-2007, 06:23 PM
Bigblock's Avatar
You can change the gear on the trans end of the cable.You need one with less teeth to speed the cable up.If it has no cable then there should be gears available from Toyota for the sensor in the side of the trans.
smthwsn357
05-01-2024 07:28 AM
coffey50
07-28-2015 10:55 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
TammyMarie
07-15-2015 11:14 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: 2wd speedometer gear options?
