2wd speedometer gear options?
Do we have any factory or aftermarket options to correct for larger tires? Can't find much info on it. I'm looking for mechanical speedo for 91 model year. I have 235 75 15 tires and stockers, according to door sticker, 195 75 14. Thanks!!
You can change the gear on the trans end of the cable.You need one with less teeth to speed the cable up.If it has no cable then there should be gears available from Toyota for the sensor in the side of the trans.
