285x75x16R fitment HELP
that it? they are coming on wheels already, im doing a swap (wheels and tires), so there will be little rubbing? but i can fit them with out MAJOR rubbing? or do i have to chop somewhere to fit?
Not many folks here can help you, as most don't jump to a 16inch rim. Stick em on, you should be fine.
Depending on back spacing, you should fit okay. Those are basically a 33x11.0 tire, and you can run 33x10.50's on that truck with zero lift.
You will probably need to pound back your pinch weld, but i would bet that would be all. You may need to pound it pretty good.
Good luck, let us know how they look.
i will thank you so much for the info AxleIke, i will find out early this week, i go in tomorrow to find out, i'll be sure to post pics right away!
heres a pic of the vehicle they are coming off of, im parked next to it, that Mitsubishi belongs to a friend of mine who wants to be able to lower the Tbars some in the front and put his wheel arch extensions back on with worrying about rubbing - http://www.cardomain.com/ride/2405186/3
http://www.discounttire.com/dtcs/infoTireMath.dos
About a 33x11.25
I hope so. I plan to add these on my Classic locks
About a 33x11.25
it depends, check here, accord to here it is 32.8x11.5?! http://www.redrock4x4.com/tech/tire_...&method=metric
kawazx636
Oct 6, 2021 03:03 PM
Ritzy4Runner
10
Jan 14, 2012 07:11 PM
