23 Mpg!!
Old Nov 20, 2006 | 06:50 AM
TNRabbit's Avatar
23 Mpg!!
I just came back from a 1400-mile trip and I managed to get 23 (YES!TWENTY THREE!) mpg on the return leg driving at a pretty steady 70-75 mph. OMG! The truck ran great; I even managed to see 110 mph for one stretch, and drove @ 90 for about 100 miles. Running like a top! WOW!
Old Nov 20, 2006 | 07:00 AM
YotaFun's Avatar
DAMN!!!!!!
For a 3.Slow...
That is amasing I think...
But I have a 3.4L and average that if the oil is changed and the air pressure is good, and filter is clean, and the gas is of a decent grade...
Old Nov 20, 2006 | 07:37 AM
kmcc78240's Avatar
:bigclap: Congrats did you have a tail wind. I just managed 16.87 miles per gallon mix of city and highway
Old Nov 20, 2006 | 08:49 AM
95RunnerSR5's Avatar
ugh i hate you rabbit...i average 15.5ish city and highway driving
Old Nov 20, 2006 | 09:22 AM
dcg9381's Avatar
down hill?
Old Nov 20, 2006 | 09:27 AM
da_bigg_wigg's Avatar
The runner must have been idling on a trailer or something
Old Nov 20, 2006 | 09:42 AM
traben27's Avatar
23?! i feel lucky if i get 15 city/highway...
Old Nov 20, 2006 | 09:51 AM
Swissdrums's Avatar
Nice man, mines the same way. I did a roadtrip a month ago with 22.5 with 3 other guys and a full trunk.
Old Nov 20, 2006 | 05:06 PM
Bumpin' Yota's Avatar
110? What did you do to enable it to run at that speed? All 3vz-e's have a spark cut at 104-106mph....
Mine is dead center on 105.
On the drive home (to gainesville, FL at the time) from Nashville, TN, I followed a buddy home at 60mph. My buddy had a chevy duramaxx dually pulling a car hualer so I was drafting too. On most of the downhill grades I just took the truck out of O/D and didnt touch the brakes or the gas! When I went to fill up (only used 1/2 tank) I got 27MPG!!! The rest of the drive on flatter ground my toy got 23mpg as well, which at the time was better than my average.
But in realistic driving scenarios the best ive gotten has been 25mpg - a tiny bit of tail wind, 65mph cruise, no rpms above 3400rpm and 225/75r15 car tires...lol
Old Nov 20, 2006 | 05:21 PM
T-town's Avatar
I had a 91 3.0 pickup and I got up to 110 on a flat road. Maybe the limiter varies.
Old Nov 21, 2006 | 02:31 AM
TNRabbit's Avatar
The difference in limiters is probably due to speedometer variances.
Luckily (?), I was only doing 90 mph when the VA State Trooper saw me (ouch).
Old Nov 21, 2006 | 04:12 AM
mt_goat's Avatar
Are your tires worn down? That will spin your speedo faster and make your gas mileage seem better.
Old Nov 21, 2006 | 04:18 AM
TNRabbit's Avatar
Nope; speedo is spot on.
Old Nov 21, 2006 | 05:07 AM
mt_goat's Avatar
You may be running dangeriously lean. Maybe your fuel pressure is dropping for some reason. It is great to get that kind of mileage with the 3.0 but it's not normal. Unless you had a 40mph tailwind that day.
Old Nov 21, 2006 | 11:22 AM
Greg_Canada's Avatar
What if you have tires that are 33" tall, and your stockers are 28, with stock gears, and you hit 95mph indicated?
110mph!
I could have gone faster, if the hill was longer! lol (and didnt have 5 ppl in the truck).. i've hit 105 with 30" tires tho.. no cut at all....
Old Nov 21, 2006 | 11:42 AM
itsmeagain5789's Avatar
were you rolling down hill with the engine turned off or what? if im lucky i will get 15 mpg
Old Nov 21, 2006 | 12:39 PM
sdstud212001's Avatar
maybe he was tailgating a semi truck
Old Nov 21, 2006 | 01:02 PM
Squiddy's Avatar
mileage...
Well, I've been running a '92 X-cab, same engine, for years, and steady 23-ish on the highway, so I believe it...
Old Nov 21, 2006 | 03:07 PM
TNRabbit's Avatar
I used to get really crappy mileage but a new 02 sensor, Denso Iridium plugs, NGK wires, Denso distributor cap & major cleaning of the plenum & intake manifold, then fixing a huge d@mn vacuum leak by the A/C Idle Up made all the difference in the world!
Longbed 90
Mar 11, 2019 12:38 PM
primordialbeast117
Dec 19, 2015 12:23 PM
kawazx636
Sep 29, 2015 08:22 AM
83
18
Sep 21, 2015 06:15 PM
Gargoyle_Runner
Aug 28, 2015 01:36 AM
