22rtec swap
Old Aug 29, 2006 | 03:45 PM
tampabayota's Avatar
22rtec swap
can i swap a 22rtec to a 22re
Old Aug 29, 2006 | 04:00 PM
Elton's Avatar
i dont see why it wont work but you may need a few items from the 22RET
Old Aug 31, 2006 | 07:40 PM
dcg9381's Avatar
Clarify your question.
Can you swap a turbo / manifold /boost tubes from a 22RTE? Sure, they'll bolt on.. Minus the oil feed and drain needed for the turbo (they can be drilled and tapped fairly easily)... It'll all bolt up.
The 22RE is a "high" compression engine.
The 22RTE is a low compression engine... I assure you that bolting a turbo with no other changes on to the 22re has been tried before and resulted in some very expensive engine damage.
You can swap a complete motor into your rig, you'll need the harness and ECU also.
You can put an aftermarket turbo on a 22re, but for best results you need to use turbo pistons... A high compression 22re can be run with a turbo also at minimum boost with good fuel, but it needs to be tuned and isn't going to work for long if you don't deal with fuel system...
I have a 1988 4 Runner with a 22RE.
It's going turbo. Check my sig. It's not an inexpensive undertaking.
It can be done on a budget, but you HAVE to take care of the fuel system otherwise you won't have a motor left.
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Gevo
Jul 29, 2015 11:15 AM
GeoRoss
Jul 24, 2015 03:03 PM
