22re wont start its trying but just wont? help
Old Jan 15, 2010 | 02:21 PM
854runner4x4's Avatar
ok i have an 85 4runner i already started a thread about it but no ore response heres the link look at it please https://www.yotatech.com/forums/f116...e-help-201155/....
Old Jan 15, 2010 | 02:23 PM
ok and i the timming is been checked like 10 times its getting gas its getting great spark.....to every wire.... when i crank it over and dosent start i pull a plug out and its wet with gas so i know its getting fuel..... stil dosent start up i mean its acts like it wants too but just never does?
Old Jan 15, 2010 | 03:03 PM
bipolarandproud's Avatar
sounds like a problem there . .. How wet it the spark plug ? flooded ?
bump
Old Jan 15, 2010 | 04:03 PM
yah i say so
Old Jan 15, 2010 | 05:15 PM
myyota's Avatar
If you truck has a solenoid resistor and it goes bad your truck won`t start. I had the same problem with my 86 4Runner. I had good spark and fuel but it just wouldn`t start, i checked everything i could think of and still nothing, i had a spare solenoid resistor and just for the heck of it i decided to try it, and to my suprise it started on the first try. So see if you have one on your truck and check it out.
Old Jan 15, 2010 | 05:23 PM
what does it look like and where would i find it?
Old Jan 15, 2010 | 05:35 PM
myyota's Avatar
Its on the passenger side fender behind the fuse box and has two yellow plugs comming out of it.
Old Jan 15, 2010 | 05:54 PM
oh and it looks like theres fins on it
Old Jan 15, 2010 | 06:03 PM
myyota's Avatar
Yes, thats it.
Old Jan 15, 2010 | 06:47 PM
abecedarian's Avatar
ok i have an 85 4runner i already started a thread about it but no ore response heres the link look at it please https://www.yotatech.com/forums/f116...lp-201155/....
it's wasn't even 24 hours since the last post on that thread and you start a new thread?
Old Jan 15, 2010 | 09:45 PM
screech's Avatar
9.8 volt drop is alot. normally should only be 1v or so drop.
have you tapped the starter? tap it a couple of times with a ratchet or wrench. unhook your battery first to prevent a slip.
Check your grounds, do continuity checks between the frame and your connection point.
Old Jan 16, 2010 | 03:00 PM
myyota's Avatar
Were you able to figure out the problem ?.
Old Jan 16, 2010 | 04:05 PM
no i just got back from the auto parts store and nobody even knows what this part is lol
Old Jan 16, 2010 | 04:09 PM
misterzee's Avatar
not surprising. Junkyard item, or stealer item.
Old Jan 16, 2010 | 06:34 PM
myyota's Avatar
Im not suprised, its not a common part thats normally replaced, so you would need to look in a wrecking yard or go to the dealer. When mine went bad i found one at pic n pull. In your case, go to pic n pull on Sunrise Blvd, I go there alot, you should be able to find one there. (pocket part). Grab an extra one for a spare.
Old Jan 16, 2010 | 08:12 PM
yah thats where ama head tommoro....like early hey where u from "myyota"
Old Jan 16, 2010 | 08:43 PM
myyota's Avatar
I live in San Pablo, a little over an hour from you. Im up there at pic n pull about every other weekend, and also because my 4Runner is at my cousins house by placerville, so i go up there to work in it.
Old Jan 16, 2010 | 09:24 PM
Teuf's Avatar
Well dang i need to go there too....
Old Jan 16, 2010 | 09:32 PM
oh yah whats up wit yours? and "teuf" you got the same problem or what? lol
Old Jan 16, 2010 | 09:36 PM
Teuf's Avatar
Oh no prob, just looking for a tail gate, for an experiment.
