22RE VS V6 differentials
Old Jun 23, 2017 | 02:07 PM
Thord's Avatar
Ok guy's rush question , i need to know the difference in ratio between the 4x4 v6 differentials ratio and the 22RE differential ratios.
1991-1994 erra
There is a V6 truck for sale near my place for really cheap , i just wanna make sure the V6 differential are geared longer than the 22re.
Simply tell me , on OEM size tires , does the V6 engine run slower than the 22re at the same mph?
Thanks !
Old Jun 23, 2017 | 02:17 PM
wyoming9's Avatar
Red face
Best answer maybe!
Depends what gears are in both vehicles
This is off the top of my head so might be off.
Autos and Manuals had different ratios
Being Toyota`s no way without looking just what gears are in the vehicle
Just what are you looking to do??
Old Jun 23, 2017 | 02:22 PM
Thord's Avatar
I have a 1991 w56 with a vw tdi engine attached to it , the whole mechanic is in a 4x4 4runner with 22re differentials.
A 4w4 V6 truck just poped on an ad near my place , i want a pickup more than a 4runner , and if the gearing is taller on the v6 , it's a win for me , i currently cruise at 3k rpm at 60mph ( remember it's a diesel engine now )
Old Jun 23, 2017 | 02:34 PM
wyoming9's Avatar
Red face
What gear ratio is in your vehicle now??
You just need to go lower numerically
If you have 4.10`s now maybe 3.90`s would drop it to wear you want
There is most likely a gear ratio /Tire size chart floating around some place.
Old Jun 23, 2017 | 05:09 PM
Thord's Avatar
I don't know my gear ratio , all i know is that i have original 22re stock differential.
All i wanna know is what the 22re diff ratio is and what the V6 diff ratio is.
I'm pretty sure toyota used the same ratio for v6 all the way from at least 1991-to 1995 , same for the 22re...
I think i'll jack the rear end and turn the shaft by hand and do the maths , no one seems to know the answer...
Old Jun 23, 2017 | 05:30 PM
millball's Avatar
The ID plates on the trucks know the anwer. See this: http://home.4x4wire.com/erik/diffs/
Old Jun 23, 2017 | 06:40 PM
Zach_trun's Avatar
My 93 v6 SR5 manual pickup has 4:30..... Not sure if that helps or not
