22re swap to 22r converting to efi...greatly need advice/input
Old Apr 1, 2008 | 11:30 PM
22re_mud's Avatar
so i have a 1993 Toyota p/u 4x4 it has a 22re in it now i spun a rod bearing however and picked up an 89 22re with 80k for $200 so i am going to swap motors and then rebuild the my original motor latter. i am kinda thrown off tho the motor i purchased says 22re on the valve cover but had a vacuum advance on the distributor and no knock sensor. does anyone have any clue on this? also i wanted to know how to put a knock sensor in and weather or not i could use the vacuum advanced distributor for the efi setup? all input will be appreciated.
Old Jul 5, 2013 | 01:12 AM
Daniel L's Avatar
Your motors are different years. They changed designs ect. You may want to buy an 89' 22re wiring harness/computer. Had a buddy hook up a 86' 22re to a 1991 truck that was originally a 22re, and it wouldn't run right and was missing some different connecters, ect. Instead of going through the whole engine he bought a wiring harness and computer off ebay. Hooked them up and it ran fine. Also my brother blew his eclipse engine, paid $900 for a used one, we put it in and it only ran on 2 cylinders but before we figured out that it was the computer he paid $780 to a mechanic to look it over and check every thing. Just better to get the same year computer/wiring harness with the engine.
Old Jul 5, 2013 | 08:28 AM
Bullet22r's Avatar
as daniel said different years different designs, the older 22re didnt have a knock sensor but used the dizzy as a sensor.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
crashburnoveride
Jul 10, 2015 06:39 AM
