22re smog problems
Old Mar 19, 2013 | 04:27 AM
piratelegs's Avatar
adjust valves
Check valve lash to make sure u are getting optimal combustion.
Old Mar 19, 2013 | 04:28 AM
piratelegs's Avatar
Vacuum lines too, might have a leak.
Old Mar 19, 2013 | 04:13 PM
Philbert's Avatar
triple check your vacuum lines. then check them again.
This was an issue for me last time I failed.
Google for a vacuum diagram and then match them up
Old Mar 19, 2013 | 05:36 PM
TravRich's Avatar
How do you suggest checking the lines? I heard spraying throttle body cleaner on the lines when the truck is running is a good way. Any other suggestions?
Old Mar 19, 2013 | 06:31 PM
  #25
Philbert's Avatar
Yes that's a good way to find leaks
But make sure they are also attached correctly....that was my error
Old Mar 19, 2013 | 08:06 PM
  #26
TravRich's Avatar
Happen to have a link to diagram you used?
Old Mar 19, 2013 | 09:27 PM
  #27
Philbert's Avatar
http://lmgtfy.com/?q=22re+vacuum+diagram#
Old Mar 19, 2013 | 10:16 PM
  #28
Co_94_PU's Avatar
Old Mar 19, 2013 | 10:29 PM
  #29
Philbert's Avatar
I don't think i have the egr temp sensor wire in your diagram, and i have a CA truck.....strange.
Old Mar 20, 2013 | 05:00 AM
  #30
TravRich's Avatar
Thank you, to both of you.
Old Mar 20, 2013 | 04:52 PM
  #31
TravRich's Avatar
So this weekend I'm gonna do a valve adjustment, replace the o2 sensor, new valve cover gasket, spark plugs, rotors, wires, dist, run a compression test, replace pcv valve and grommet, and check my vacuum lines for leaks and trace them to make sure they are all hooked up correctly. Gonna be a busy weekend, any other things to do while I'm at it
Old Mar 24, 2013 | 08:42 AM
  #32
TravRich's Avatar
Decided against replacing my rotor, dist and wires as they look almost new. Replaced the plugs and pcv valve/gromet. Also did my valve adjustment and put on a new valve gasket set. I've got my denso oe identical o2 sensor on order and it will be here Tuesday. Hopefully next weekend I can go to the hobby shop and use their tools to test the pair and evap system and do my compression test.
Old Mar 24, 2013 | 08:43 AM
  #33
TravRich's Avatar
Oh no vacuum leaks and I believe my vacuum lines are hooked up correctly but I'm gonna check again
Old Mar 24, 2013 | 12:54 PM
  #34
Co_94_PU's Avatar
You need to test those ignition wires with an Ohm meter, should be under 25 Ohms. Visual inspection just isn't enough. Also on the distributor cap if it's not copper, aluminium oxide is clear and so it's hard to see.
jbv808
Aug 6, 2021 04:47 PM
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
jasonty
41
Dec 23, 2018 01:00 PM
timmJ
Jul 7, 2015 02:01 PM
