22re sensor
Old Feb 4, 2020 | 07:32 PM
redneck17's Avatar
22re sensor
What is this sensor in the top left of this pic t
Old Feb 4, 2020 | 08:45 PM
millball's Avatar
Knock sensor
Old Feb 4, 2020 | 08:58 PM
redneck17's Avatar
22re sensor
Thanks for the quick reply
Old Feb 5, 2020 | 10:27 PM
2ToyGuy's Avatar
Not to argue, but the FSM, if I'm reading it right, says that that's the oil pressure sensor/switch, either for the gauge or just the idiot lite.
But hey, I may well be wrong...
Pat☺
Old Feb 5, 2020 | 10:51 PM
RASALIBRE's Avatar
Pat☺
Oil pressure sender/switch is the silver cylinder below the oil filter.
The sensor at the top left is for sure the knock sensor.
Old Feb 6, 2020 | 08:37 AM
Co_94_PU's Avatar
Maybe some one has a rotated image.
You can see the knock sensor, an oil filter, an oil pressure sender, and two bolts of the motor mount (those are important because they tell you that's the front and lower if the engine.)
PS, pretty sure the switch is smaller but I'm old and forgetful.
Old Feb 6, 2020 | 01:07 PM
2ToyGuy's Avatar
I was just going by the FSM for 86-89.
Am I mistaken that it shows the sensor upper left above the oil filter is the pressure switch/gauge sender? I always thought (there I go thinking. Gets me in trouble every time... ) that the knock sensor was at the back of the block, up higher, nearer the head/block line.
Anyone have an actual photo of it?
Pat☺
Old Feb 6, 2020 | 01:11 PM
millball's Avatar
The original poster posted an actual picture of it.
Old Feb 6, 2020 | 07:22 PM
Co_94_PU's Avatar
Pat☺
Compare the line drawing you are looking at to the photo above..
Can you pick out the oil galley and the undrilled port?
Old Feb 8, 2020 | 03:51 AM
wallytoo's Avatar
indeed, in the photo, the undrilled port is directly below the knock sensor, to the left of the mounting boss.
Old Feb 9, 2020 | 09:55 AM
xylicon's Avatar
The upper left sensor is the knock sensor, here is a picture of my long block on the stand with better detail. Knock sensor not currently installed.
Old Feb 9, 2020 | 12:01 PM
2ToyGuy's Avatar
OK. I was just going by the drawing I found in the FSM. Obviously, I was mistaken.
Thanks for correcting my impressions. I know better now
Pat☺
Old Feb 15, 2020 | 08:44 AM
Jami Rudy's Avatar
100% knock sensor
X94YODAX
Aug 11, 2012 06:14 PM
yotarover
Nov 9, 2010 09:25 AM
PhdNPrerunners
May 3, 2010 11:08 AM
JohnnyB
Mar 27, 2007 05:54 AM
Elton
16
Aug 13, 2005 11:57 PM
