22re runs rich pull vacume line runs smoother
Old Aug 16, 2023 | 06:38 AM
Peanutt's Avatar
Pretty much what the title says. new 22re swap, motor is running rich, i changed afm twice, 02 twice, swapped ecm also. I was pulled a vacum line then it leaned out and idled perfect. Any help would be appreciated.
Old Aug 17, 2023 | 06:55 PM
87-4runner's Avatar
You changed the AFM, but have you tried adjusting the AFM?
Old Aug 20, 2023 | 09:35 AM
old87yota's Avatar
The AFM should be pre-set from the factory and should not need adjustment.
Something else should be the real problem.
Old Oct 5, 2023 | 06:07 AM
Zsule's Avatar
Same problem I'm having. My 1987 Extra cab SR5 22RE is running rich and I haven't a clue why.
Old Oct 5, 2023 | 07:59 AM
mechkw's Avatar
Stop throwing parts at it and diagnose it. Possible Temp sensor? Double check the vacuum hoses for proper location. Make sure coolant is flowing everywhere. Grab all the hoses and make sure they are hot
ltjman22
Sep 22, 2012 01:39 PM
LukaDuke15
3.4 Swaps
Oct 6, 2009 07:27 PM
eightnine
Oct 11, 2008 04:12 PM
swaycleveland
Dec 6, 2007 12:59 PM
