22RE running rough.
Old Mar 15, 2009 | 02:35 PM
IngSoc's Avatar
22RE running rough.
Ok so heres the skinny. It idles fiine when I first start it but after she warms up it idles a bit rough. Also in the rain it like to act a bit more rough I checked inside my cap and its dry. Since im a newb at this mechanic stuff wondering what yalls input would be. Thanks again YT
Old Mar 15, 2009 | 02:43 PM
Junkers88's Avatar
My first thought would be the cap/rotor since you said it gets worse when it rains, but you checked that. Have you checked it after driving home after a rain? It might have a hair line crack that only opens up after the motor (and thus the cap) is warmed up, plastic does that when it gets warm.
Perhaps one of the plug wires is cracked also? Are they worn/old/dry rotted?
I'm thinking the moisture aspect of your issue points towards the ignition system.
(Oh and your "E" and "L" are switched in "axle" in your signature) *grin*
Old Mar 15, 2009 | 02:52 PM
iamsuperbleeder's Avatar
you could try to dialectric grease up all the major important electrical connections like the TPS, ignitor, all the plug wire ends (as well as the coil wire), the dizzy plug in, and AFM plug
like mentioned by Junkers, if it get's worse with moisture, it's more than likely ignition related, but, it could also be a vacuum leak, so you could try to search for that as well
Old Mar 15, 2009 | 05:28 PM
Flash319's Avatar
Also make sure that your intake tube is sealed very good and not leaking.
Old Mar 15, 2009 | 05:50 PM
IngSoc's Avatar
Awsome pretty much what I thought with a cuple added bonus... Like getting a free spell check on my sig. :smile: Good to know yah have my back.
Old Mar 15, 2009 | 06:28 PM
lmao, everyone's hear to help each other out man!
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
bryan34w
Jul 6, 2015 05:53 PM
