22RE running rich
Old Sep 6, 2006 | 06:18 PM
cweich's Avatar
Question 22RE running rich
Hello, thanks for all the help so far on my other project. Here is my problem, i have a 1985 yota pickup with a 22re with an auto trans. The truck run ok, but is smokes alittle white smoke...smells like oil, what is normal cause for this in these engines?
second, when you rev it up the smoke turns dark grey to black, clearly its running rich. What sensor or sensors might cuz this? I have done no mods to it, it is how i bought it. wanted some opinion before i just take it apart. yotas are new to me. Thanks for the help, Chris
Old Sep 6, 2006 | 06:24 PM
Elton's Avatar
could be the o2 sensor
Old Sep 6, 2006 | 06:40 PM
yota_krazy's Avatar
white smoke = coolant....unless it happens on a cold start and that would just be condensation in your exhaust. Possible blown head gasket.
Old Sep 6, 2006 | 06:43 PM
Elton's Avatar
may check under your oil cap should be kinda milky
Old Sep 7, 2006 | 06:45 PM
mattjam's Avatar
If its putting out black oily exhaust when you rev it, I'd say your AFM is out of adjustment.I had the same thing, adjusted the afm a few clicks leaner: problem solved.
Old Sep 7, 2006 | 07:19 PM
cweich's Avatar
What is the afm and where do i find it. Thanks for the response!
Old Sep 9, 2006 | 12:24 AM
Spanky's Avatar
search, search, search, search, search.... should i say it again ?
Old Sep 9, 2006 | 03:35 PM
84sr5yoty's Avatar
Its that big chunk of metal that covers the air filter.
Here's how to test it
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old Sep 11, 2006 | 07:52 AM
cweich's Avatar
Under the cap is clean.
Old Oct 3, 2006 | 10:15 PM
Spanky's Avatar
so what is your conclussion? its been almost a month and no response! whats the dealy-o ?? help us.. so we can help you
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
