22re rebuild rant
Old Oct 19, 2007 | 08:28 PM
Targetnut's Avatar
Tijuana rebuild
Originally Posted by paxil4x4
For a proper rebuild you cannot build a light truck engine in the frame. The block needs to be tanked to clean out all the oil passages and remove scale. Plus all the freeze plugs should be changed at the same time. The way he is going about is a Tijuana rebuild at its finest.
Around here we use a different ethnic slant to describe this type of hap-hazard repair technique but I think that about covers it
Old Oct 19, 2007 | 08:31 PM
just a 22re's Avatar
shes all honed and im about to rering and put back together but im takling the pistons to get checked and the block not worped head just got back from the shop and oh yes i know what im doing
Old Oct 19, 2007 | 09:12 PM
dcg9381's Avatar
What is it that they check the pistons for?
Piston bores tend to wear unevenly.. Hard to bore one out in the engine bay.
Old Oct 20, 2007 | 05:36 AM
n4ynu1010's Avatar
HEHE yes , but I would imagine if your not taking it out then a hone , re-ring and removal of the lip at the top of the bore would be better than just leaving them in till next time eh
Old Oct 20, 2007 | 07:03 PM
  #25
toyotaman11's Avatar
I would remove the engine to rebuild it the proper way ... but thats just me. hopefully your "rebuild" goes well for you, good luck.
Old Oct 22, 2007 | 10:59 PM
  #26
yeah yeah yeah YEAH!!!!!!!!!!!!!!!!!!! ALL OF YOU CAN KISS MY BUMPER LOL JUST PLAYING ok so i just took the block out so you all win got pissed and took her out much easier now but my back will thank me in the morning
Old Oct 23, 2007 | 10:23 AM
  #27
n4ynu1010's Avatar
Motor Rebuild
As long as your bumper is clean I will kiss it for you ROFL
I will not flame you but if your gonna go that far why not just do it all so you can forget about it for a long long time .
Thats all they are all saying , they just don't want to see you do half or 3/4's of it and then in 3 months wipe your rings or a bore and then have to tear her down again .
Also from the Old School of Wisdom :
We would always frown on putting fresh heads (usually milled thereby increasing compression) on a old or worn bottom end because in no time at all the increased load on the bottom end from the top end being rebuilt would result in all kinds of failures - mains,rods,wristpins,ring lands.
So if you tear it all the way down and rebuild completely then it is all happy and gets to wear in together .
Note : Use the buddy system to remove your motor (and no I do not mean the "Don't ask - Don't tell" buddy system) , ask a buddy for a hand or to borrow his engine lift , what good is a fresh motor if you can't sit and drive comfortably
Old Nov 1, 2007 | 11:01 PM
  #28
ok time to bring this back up well i got a new cam new crank new rods new pistons new valves, gides, and seals new gaskets new chain and gears new rings new front and rear mail seals new bearings new fuel filter anything missing here?? and if you want i can post up pics but i thing swampthing will then dis own me i painted mine go green and my girl wanted thevalve cover purple bt it shifts to blue in most lights lol
Old Nov 1, 2007 | 11:42 PM
  #29
DilutedImage's Avatar
Haha, that's great. Post up some pics of Barney's new motor!
Old Nov 2, 2007 | 12:36 AM
  #30
Ganoid's Avatar
this is my 4th rebuild with it still in the engine bay so ha i like doing it this way its easier
I would think the first 3 failures would have tipped you off about the in-frame rebuild method?
hehe couldn't resist but I see you have come to your senses. I pull 3.0 V6's to do head gaskets because its easier to work around the motor than from the top only.
Old Nov 2, 2007 | 01:29 AM
  #31
Trumpfan's Avatar
go team lazy?
Old Nov 2, 2007 | 12:13 PM
  #32
yes go team lazy lol i guess people are starting to see that but thats been there from the start date lol but here go some pics swampthing dont be mad!!!
thats the green motor block
this is the purple fan as with the valve cover is the same color
the cool pulleys
the shiny oil pan YAY lol
my locked bearnings oh yeah i laughted to
and thats just the motor block in the frame rails yet
Old Nov 2, 2007 | 12:21 PM
  #33
Diesel_Freak's Avatar
yeah well i dont have all the thing to do a rebuild with it out and this is my 4th rebuild with it still in the engine bay so ha i like doing it this way its easier
If you're on your 4th "rebuild" of a 22RE then you're doing something wrong mate... Is it possible that you've just torn the motor apart 4 times to do 1 rebuild???
Old Nov 2, 2007 | 12:39 PM
  #34
not to do them on 22res this is my first 22re rebuild ive done hondas 4G63's crap like that but this one will have the most power he he or at lest be the only turn key in year 2598 lol
Old Nov 2, 2007 | 12:51 PM
  #35
surf4runner's Avatar
new block???
Old Nov 2, 2007 | 01:54 PM
  #36
the block is AOK no need but yeah if that happens im done!!
Old Nov 2, 2007 | 03:22 PM
  #37
dcg9381's Avatar
Agree.. These motors are rock solid.
After 4 "in frame" rebuilds, are you really saving yourself time overall?
Old Nov 3, 2007 | 03:06 PM
  #38
like i said this is the first time i have ever even looked at a 22re
Old Nov 7, 2007 | 10:24 PM
  #39
so just a update for everone!!!! got all the parts in today yay so i had to go to work on this one!! cranks in pistons in reringed and roded!!! heads on pans on (pans gotta come off to get the timing cover on) new 268torker cams in valves will be set to lash poits as engbulder said to need a flat head to do that ( yes i got a fealier gage) and everythings torked dont to toyota specs!!!!! just waiing till tomorrpw and ill kill her!!! then shes getting droped in and started for the first time yay i cant wait!!!!!! and yes i used rebuild lube on everything just though i would let you all know how its going!!! on and the timing is set chain and so is the disb lol
Old Nov 9, 2007 | 08:03 AM
  #40
n4ynu1010's Avatar
Cool , vroooooom vroooom
bigjstang
Jun 2, 2025 03:56 PM
coleypull15
Nov 3, 2015 07:41 AM
jerusry
Oct 19, 2015 05:28 PM
shisha1999
Sep 21, 2015 08:22 PM
shadowbirdie
Jul 21, 2015 10:38 PM
