22re new motor no power
Old Oct 1, 2012 | 04:34 PM
Drunner's Avatar
pm'd about fsm thanks
Old Oct 2, 2012 | 06:57 PM
Drunner's Avatar
ordered my tps today should be there in the morning hope it goes well and I hope this fixes it
Old Oct 2, 2012 | 07:01 PM
racerflea's Avatar
Was that fsm any help?
Old Oct 3, 2012 | 03:24 PM
Drunner's Avatar
I just checked and didnt get it I will pm you my email adress again maybe I typed it wrong lol
Old Oct 3, 2012 | 08:34 PM
  #25
Drunner's Avatar
a little update got my tps and it was bad right out of the box which I guess is more common then I thought so I will get another one tomorrow and try it
Old Oct 3, 2012 | 08:57 PM
  #26
schwyter's Avatar
Please, for the love of god, use punctuation. I'm getting a headache reading this super-relevant thread, since I'm about to fire up my 87 22re rebuild this weekend, and don't want to run into the same problem you are.
Old Oct 4, 2012 | 06:39 AM
  #27
snobdds's Avatar
I've never heard of this before...? TPS usually never go bad, they just need adjustment.
Your TPS may help to fix your problems, but your ignition timing being off will still make it have no power. You still haven't answered how you know your cam and ignition timing are correct.
Old Oct 4, 2012 | 02:00 PM
  #28
Drunner's Avatar
any sensor can go bad. When I had my 73 satellite I pulled 3 altenators right off the shelf and had them test them before I bought them and they were all bad. If your getting a headache then get some glasses LOL
Old Oct 4, 2012 | 02:45 PM
  #29
snobdds's Avatar
For some weird reason, I know how this will end.
Old Oct 5, 2012 | 10:22 AM
  #30
stanz's Avatar
x2 on the timing vote.
My experience with TPS's and throttle bodies is that they rarely ever fail, typically they just need a good cleaning and calibration -- my 86 is a perfect example, not sure it ever got any love until this year, made a tremendous difference. Having a new one fail right out the box is especially uncommon.
Old Oct 5, 2012 | 01:57 PM
  #31
Drunner's Avatar
Ok new TPS fixed it runs great now and has the power I kinda thought it would. Now I just need to get a header so I can get rid of the exaust leak. A TPS can go bad just like any other think on a car/truck. Could not adjust my old one no matter what I did so I bought a new one (once I got the second new one) and bam it works good now
Old Oct 8, 2012 | 03:43 PM
  #32
Drunner's Avatar
Stanz I called LCEngeniering (when I bought the first TPS) and they said that it is more common than you think to get a bad one right out of the box
Old Oct 8, 2012 | 04:34 PM
  #33
stanz's Avatar
Anything's possible, but always keep in mind that calibration can also be a culprit for new parts.
Old Oct 9, 2012 | 07:24 AM
  #34
snobdds's Avatar
Sorry, but TPS does not fix a power issue. Correcting the timing does. I knew where you were going with this before you probably knew.
For future searchers, putting a new TPS will not magically fix a power lag in the upper RPM's. It's impossible quite frankly. Making sure the ignition timing is correct, however, will fix a power lag by making the dizzy fire at the correct time.
Old Oct 9, 2012 | 07:29 AM
  #35
waskillywabbit's Avatar
Originally Posted by waskillywabbit
One tooth off it will run like ass.
:wabbit2:
:wabbit2:
Old Oct 12, 2012 | 03:02 PM
  #36
Drunner's Avatar
Well anybody is welcome to come by and we can put on the old TPS and then the new one and see for yourselfs LOL. Yes the timing was a little off when I put the new one on (instead of 5 deg it was at 0) and adjusted it because the old one was not letting me adjust the timing right, but it was not off by much. In my experience with machanics anything is possible LOL
Old Oct 12, 2012 | 06:24 PM
  #37
stanz's Avatar
I declare this thread done. Drunner, I believe you in that you got a bad TPS. Not trying to ride you on this.
Old Dec 11, 2012 | 11:20 AM
  #38
gailensnow's Avatar
I'm having the same problem with my fully rebuilt 22re, .20 over, torkr cam. And absolutely no power! Could it be vacuum related???
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
AaronM
Jul 8, 2015 07:15 PM
karbin
Jul 5, 2015 11:37 PM
