22RE lower intake manifold removal
Old Nov 15, 2014 | 04:21 AM
Chikn Hawk's Avatar
I removed 7 12mm hex head screws and 4 addt'l 12mm hex head nuts. Is there any others I need to remove? I read there's two allen head screws as well but I cant seem to find where they're located. Piks would help or a lead to a good thread. LMK and TIA.
Old Nov 15, 2014 | 07:26 AM
wyoming9's Avatar
Red face
The Allen head bolt is just about under the thermostat housing looking from the right side of the engine
most times if it was never apart it is full of dirt making it hard to see.
It takes a 6mm allen wrench
Old Nov 15, 2014 | 04:25 PM
Chikn Hawk's Avatar
Thanks for ur response. I found it and then went at it. Is there just that one or is there another one hidden?
Old Nov 16, 2014 | 01:13 AM
wyoming9's Avatar
Red face
Just that one being the manifold has been on since the truck was born more then likely it is stuck .
Some tapping or the use of a small flat pry bar is needed to break things loose just don`t go wild and break out the 10 pound sledge hammer
Old Nov 16, 2014 | 06:47 PM
Chikn Hawk's Avatar
Ok thanks I got it off and now gona do some carb cleaning. Any advice on good and fast cleaning solvents & cleaning tools and tips?
Old Nov 16, 2014 | 10:45 PM
wyoming9's Avatar
Red face
I find Gum Cutter works Good.
Another Good one is Kano Labs Floway
Dish washer for the parts that can be removed.
Pressure washer if one is careful around the electrical parts.
The small nylon brushes work wonders.
88sasturbotoy
Jan 30, 2026 01:57 PM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
Sep 4, 2015 09:27 AM
87blyota
Jul 10, 2015 04:31 AM
