22re intermitant clicking
Old Jan 20, 2013 | 03:06 PM
Andy S Brown's Avatar
my 93 22re is making an intermitant clicking and has power loss in and out, changed o2 sensor, computer, fuel filter and pump still nothing. i think fuel pres regulator ne thoughts???
Old Jan 21, 2013 | 12:10 AM
Huntingtruckcletus's Avatar
Could you describe the ticking a little better? When I think of ticking I think of an exhaust leak, or the loud injectors in these things. Any work done prior to the ticking noise or did you just notice it one day?
Old Jan 21, 2013 | 04:51 AM
thu clicking is on and off not a slow click but fast, and dosent change with idle realy, definitly not valves im experienced with motors and like i said it goes away but its awfuly lowd and hard to pin point, at one point in time i thought a rockerarm was shot but not so sure im gunna do a HD timing kit so if its in there ill find it. its not just when its cold it comes and goes whenever it wants somtimes not for days!! then lasts a few minuts or so, somtimes wen im driving it happens like i said compleatly random. u seem to have thu same truck
Old Jan 21, 2013 | 04:53 AM
i also get check engine and run diag, and its a rich and then lean code usualy not both whats up with that?
Old Jan 21, 2013 | 05:06 AM
BamaYota1's Avatar
Leak in your exhaust before the 02 is my guess.
Old Jan 21, 2013 | 05:37 AM
waskillywabbit's Avatar
What do the codes suggest you check per the FSM?
:wabbit2:
Old Jan 21, 2013 | 06:13 AM
BamaYota1's Avatar
What brand o2 sensor did you install?
Old Jan 22, 2013 | 09:06 AM
codes say fuel line pressure, injector, injector circut, 02 sensor, water temp sensor. ill change it all but thought i would ask first, mabie somone had this problem.
now thu fuel pump and lines and filter are brand new! water temp is not but i thought that just effected idle, computer is new, o2 sensor is a stock o2, eghast is not leaking at all just re did that. it dose not have a crappy idle, idles perfect till it runns ruff then its low along with power, but it snaps out of it and runns great! sounds like mabie a short somwere
Old Jan 22, 2013 | 09:08 AM
codes by thu book say fuel mixture lean, then fuel mixture rich!!! those r the only codes
Old Jan 22, 2013 | 09:22 AM
BamaYota1's Avatar
How many miles are on the truck? You have to be more specific. The guys on this board know everything there is to know about these trucks. Be patient. Clicking sounds are very common for a perfectly running engine.
Old Jan 22, 2013 | 10:17 AM
Have you pulled your timing cover an took a look at your guilds yet?
Old Jan 22, 2013 | 10:31 AM
i have six of these trucks and this is no normal click, it has 160,000 mles and no i havent and have had thu timing cover off and it just might b those dumn plastic guides
i have many of these trucks none have made thu noise im hearing, and yess u guys are a big help im sure u do know what ur talking about ive got thu patience just tryen to give as much deail as i can
Old Jan 22, 2013 | 11:05 AM
yeah those guilds can make all sorts or noise. If you have one that is only partially broken you could be hearing it slap the housing. This may not be the problem but its something that is quick and easy to check. Also probably wouldnt hurt to undo all your belts such as power steering,a/c, an alternator. I had a really loud clicking noise that was coming from my power steering pump pully. I know these are simple things but sometimes you just need to cover all your bases.
Old Jan 22, 2013 | 11:30 AM
yes sir i just orderd thu timing kit with steel guides, as it need to b done neways and i will check thu pump and let u know. thanks
Old Jan 22, 2013 | 12:38 PM
Discombobulated's Avatar
Is ths sum sortv txt in way to tlk nw? I hv hrd of tick but s mny thngsit cood b, hrd to sy mabe a vd wil hlp or a readble pst aso.
Old Jan 22, 2013 | 07:15 PM
Yeah it's always a good thing. If I wouldn't of drug my feet on doing my timing chain I probably wouldn't be on my 4th motor.
SubiKing
Aug 21, 2021 03:57 AM
wafoogalla
Nov 2, 2016 11:02 AM
tdsmith8
Aug 11, 2015 10:09 AM
Sandman
Jul 14, 2015 12:36 PM
cars-guy
Jul 11, 2015 07:51 PM
