22re injectors
Old Jan 13, 2020 | 09:58 AM
redneck17's Avatar
22re injectors
22re injectors are there any injectors better than the other for a stock rebuild
Old Jan 14, 2020 | 12:10 PM
old87yota's Avatar
The stock Toyota injectors still seem to be the best available for a stock rebuild.
It is best to have the old injectors cleaned and rebuilt.
Old Jan 14, 2020 | 12:52 PM
thook's Avatar
afaik, you're kinda limited, in any case, because of the voltage and fuel requirements of the injectors and the stock EFI system
Old Jan 15, 2020 | 03:07 PM
Co_94_PU's Avatar
The 22re computer fires the injectors in batch mode, this means for 3/4 of the time the fuel is just turning back into a puddle (subtext: you could perfectly atomize the fuel with a fancy injector and its still going to only suck in puddles) so there is no reason to even worry about it.. Change the screen filters and move on..
Old Jan 21, 2020 | 05:30 AM
Ralphthe4runner's Avatar
Does the atomized fuel lead to better fuel economy though?
Old Jan 21, 2020 | 11:41 AM
scope103's Avatar
Better than a carburetor? Absolutely. Once the engine is slightly warm, the fuel from the injectors is vaporized very quickly (and atomizing is an important part of that). You shouldn't get much condensing back into puddles.
Old Jan 21, 2020 | 12:27 PM
Co_94_PU's Avatar
Even the carb models benefit from the pre charge pre heat. Toyota has atleast one patent that i know
of for the 20r series for this specificly.
PS, that was supposed to be rear as sarcasm.
OlGrunt
Feb 16, 2019 02:32 PM
Flame Thrower
Vendor Advertising
Jun 30, 2014 07:40 PM
stevenf
Dec 24, 2013 04:45 PM
White4Runner
Dec 17, 2011 02:39 PM
sstockton
Mar 2, 2006 08:07 PM
