22re hard to start when cold an when it starts it idels up an down
Old Jun 8, 2011 | 11:24 PM
89_yoder's Avatar
ok i got my truck fixed a runnin an now it takes for ever to start an when it starts it will idels up then down an will keep doing that but while u drive it, it runs fine but when u stop same thing
Old Jul 17, 2012 | 11:21 AM
cabinetguy's Avatar
BUMP. same issue here
Old Jul 17, 2012 | 11:24 AM
SPARKS89's Avatar
What did you have to do to get it running? Have you checked for vacuum leaks? Adjust throttle position sensor? Check AFM?
Idling up and down like that my first guess would be vacuum leaks.
Old Jul 17, 2012 | 04:06 PM
myyota's Avatar
Check and adjust the idle, if its set to high it will caous this problem. Also check the TPS, makes sure its not bad and that its properly adjusted.
Old Jul 17, 2012 | 05:01 PM
Westly7's Avatar
I would clean the iavc first then check for vacuum leak or check the voltage on tps
Old Jul 17, 2012 | 06:56 PM
abecedarian's Avatar
A fluctuating idle is a sign of a significant vacuum leak.
If it does it warm and cold, I'd start checking around the brake booster and valve cover.
Regency
20
Jan 3, 2020 07:43 PM
Sandman
Jul 23, 2015 08:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
jmc88runner
Jun 18, 2015 03:39 PM
