22re fusible link replacement/or delete?
Old Oct 27, 2019 | 02:52 PM
yota_terror's Avatar
Does anyone know where I can find this wire with the “plate” to replace the fusible link on my 86 22re?
Alternatively, I found this thread, in which people are mentioning deleting the fusible link and replacing it with 4 gauge wire. If I go this route, do I remove that plate entirely, splice eyelets onto a 4ga wire and bolt it down to the 80a fuse?
https://www.yotatech.com/forums/f116...cement-228307/
Old Oct 28, 2019 | 05:50 AM
ev13wt's Avatar
5 Year Member
If you like fire, go for it!
Else, replace fusible link.
Old Oct 28, 2019 | 08:44 AM
Any idea where I can get that plate that the other leads are bolting to? It seems to be part of the fusible link wire.
Old Oct 28, 2019 | 11:07 AM
ev13wt's Avatar
5 Year Member
Fusible link:
90982-08188 30 A, TERMINAL:FEMALE, 30A
90982-08189 40 A, TERMINAL:FEMALE, 40A
90982-08203 80 A, TERMINAL:MALE, 80A
82620 BLOCK ASSY, FUSIBLE LINK
82620-89101
82991 WIRE, FUSIBLE LINK REPAIR
82991-89103 W/ALTERNATOR=12V 60A
Old Oct 31, 2019 | 02:57 PM
It looks like the wire with the plate seems to be unavailable.
This fusible link appears to be 8 or 12 gauge. This resource states that the fusible link should be 4 wire gauges smaller than the wire it’s protecting. If that’s the case, I should have a 4 or 8 gauge wire coming from the battery to the fusible link? Seems like a very thick wire.
https://www.whiteproducts.com/fusible-faqs.shtml
Additionally since the assembly with the plate seems to be unavailable, and I’m wanting to *replace* the fusible link wire entirely, could I cut the bottom of the plate of, put together a fusible link + wire to battery, and bolt it to the plate with an eyelet?
Old Oct 31, 2019 | 02:58 PM
Seems like the only reason the “plate” is there is to act as a bridge for the leads bolted there.
Old Oct 31, 2019 | 08:48 PM
Co_94_PU's Avatar
Why wouldn't you just reuse the plate by opening up the crimps?
Old Oct 31, 2019 | 08:58 PM
The crimp which is actually holding it secure is closest to the plate. I don't know, it seems like it'd be pretty difficult to achieve as strong of a crimp if I were to try to reuse this.
Old Nov 1, 2019 | 07:53 AM
Co_94_PU's Avatar
That second crimp is supposed to be cinching the sheath, not the wire, you can see where it used to be attached but something has caused the sheath/insulation to be pulled away.
If you're concerned about that crimp, what makes you think you can do it with a ring terminal? You might not have the tools and/or experience for this job. I'd suggest you do some research and get a few practice runs in using the crimper tool and these kinds of connections regardless of what you wind up doing. Sit down with some short bits of wire the crimps and a crimper and have a go at a few first, like anything you don't do on a daily basis it will make a big improvement on the quality.
Old Nov 1, 2019 | 02:25 PM
helidriver's Avatar
My main positive to battery wire from the plate crimp corroded through a few months ago. I used a new slightly fatter wire and ring connector to one of the screws to bypass the crimp. Seems to be working fine.
Old Nov 4, 2019 | 08:36 PM
RAD4Runner's Avatar
...could I cut the bottom of the plate of, put together a fusible link + wire to battery, and bolt it to the plate with an eyelet?
.. it'd be pretty difficult to achieve as strong of a crimp if I were to try to reuse this.
Yes and yes^^^...
.. the only reason the “plate” is there is to act as a bridge for the leads bolted there.
Well... that and to connect the fusible link to that node.
Old Nov 5, 2019 | 01:58 AM
snippits's Avatar
Would a power distribution block work? Two way, three way, and four way available. The two links below are examples of many to choose from.
https://amzn.to/2WIAF0B
https://amzn.to/34zdCb0
Old Nov 25, 2023 | 01:01 PM
runner luv'rr's Avatar
Is your ring connector fix still working? What gage wire did you use?
Would a butt splice connector to the original white wire be better than a completely new wire from the battery to the plate?
Old Nov 26, 2023 | 07:46 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I've seen that fuse wire repaired with a butt connector. Personally I'd feel better about replacing the whole length of fuse wire with new. If you're careful you can open that splice on the plate and crimp a new wire in, with a new ring terminal on the other end.
Old Apr 9, 2024 | 01:40 PM
rrowlandrramos's Avatar
Nightmare fusable link plate HELP!
At this point I don’t know what to do or think. I got the replacement fusable link wire to battery. In the process of trying to uncrimp “the crimp”
Old Apr 9, 2024 | 02:23 PM
RAD4Runner's Avatar
I would just cut off the old crimp then crimp a good lug terminal that fits the bolts on the block to the new fusible link wire.
Old Apr 9, 2024 | 07:37 PM
So I got the fusable link figured out so the truck has electric. Dashboard lights are on and Now the truck does not want to start. With the key in the ignition turning the key in the ignition the truck just clicks, clicks, and clicks. I put the jumper cables on to my tacoma thinking that the Altenator needs to be charged up as well and nothing so far.
Old Apr 10, 2024 | 03:40 AM
cashmoney00's Avatar
Did you plug the starter relay connection back in? I forgot to do that after replacing mine and was stumped for a second.
Old Apr 10, 2024 | 06:50 AM
RAD4Runner's Avatar
... the truck just clicks, clicks, and clicks.
A problem well-stated is a problem solved.
Exactly what clicks?
The circuit opening relay behind the glove box?
The starter relay in right -rear corner of the engine compartment near wiper motor?
The starter solenoid piggy-backed on the starter motor? Does the starter solenoid clunck energetically or weakly?
Old Apr 10, 2024 | 12:15 PM
That is some great questions! I will get back to this thread with answers asap. Mahalo!!!!
