22RE fuel pump/cold start injector Bosch 4 hole spray
Old Nov 28, 2020 | 01:58 PM
REDYOTA's Avatar
I bought an old 87 4Runner a while back in in non running condition. Cleaned the tank and bought a new fuel pump. Fuel pump wouldn’t run on the key so I jumped it and got the truck to run. It sounded like a box a rocks though. So I pulled the motor had it machined and I rebuilt it. I just finished everything up today and have been messing around with it.
I bought the Bosch 4 hole spray injectors. They came with a splice to replace the resistor box.
My issues are:
#1 why am I having to jump the relay to run my fuel pump. What Components do I need to check?
#2 why am I having to pop it with ether to get it started. Cold start injector and timing switch worked when I first fired it off 2 or 3 times before the rebuild and new injectors.
has anyone else ran the Bosch injectors and ran into a cold start issue?
Old Nov 29, 2020 | 08:52 AM
Jimkola's Avatar
YT Community Team
5 Year Member
You checked the 15a EFI fuse in the fuse block at the driver's kick panel? Not under the hood, but inside the cab on driver's side.
FlightofPhx
Sep 30, 2020 12:03 PM
Doug4320
Mar 24, 2018 10:11 PM
pete c
Apr 19, 2011 11:49 AM
DarkGuy13
Mar 20, 2007 02:46 PM
ripple
Oct 8, 2006 09:15 AM
