22re e85??
Old Jun 13, 2006 | 07:26 PM
Jonnym's Avatar
22re e85??
So i did a search and found conflicting info on whether or not e85 will eat the seals in my fuel system. anyone have any solid info on this?? i did get a CEL for a short moment, and idling seams a bit worse, but once it's running its ok...
'87 4x4 pu 22re 129kmi
thanks
Old Jun 13, 2006 | 07:34 PM
trythis's Avatar
I know that you can't even buy kits to convert toyotas to E85, but I never thought that that could mean they have always worked with Ethonal.... Wonder if there are toyotas in Brazil?
Old Jun 13, 2006 | 10:22 PM
kyle_22r's Avatar
an engine doesn't care what fuel it burns -- there aren't that many seals in the fuel system, either. other than the rubber lines, the only real "seals" are the o-rings on the fuel injectors.
Old Jun 14, 2006 | 10:16 AM
trythis's Avatar
Then the heck doesnt anyone sell conversion kits. I think the metal fuel lines can be eaten as well. (read, THINK, not know)
Old Jun 14, 2006 | 01:21 PM
evilcow's Avatar
Ethanol is corrosive I would be more concerned with the metal components of your fuel system than the seals.
Check this http://www.e85fuel.com/e85101/faqs/diffferences.php
Old Jun 14, 2006 | 01:22 PM
InternetRoadkill's Avatar
Alcohol based fuels like E85 require a richer combustion mixture than gasoline. The fuel injection may not like it. Also, because E85 has a lower energy content, your fuel mileage will drop 25% or so. There's also the problem with the alcohol attacking rubber and plastic components in the fuel system that were not intended to be exposed to alcohol. Electric fuel pumps also have problems with alcohol becuase alcohol attracts water. Then there's corrosion issues with the aluminum cylinder heads and intake manifolds. These issues should be less of a problem for newer vehicles, but older ones may suffer.
Wiki knows and tells all:
http://en.wikipedia.org/wiki/E85
Old Jun 14, 2006 | 07:41 PM
MMA_Alex's Avatar
ethanol can eat cheap rubber seals. It should also be noted that most of the country is already using 10% ethanol as MTBE has been phased out as a fuel additive.
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
