22re Cylinder Walls
Old Feb 21, 2018 | 05:08 PM
Crockpot's Avatar
22re Cylinder Walls
Hey everyone, I’m doing my head gasket and finally got everything cleaned up and put back together for reassembly but my cylinder walls are looking pretty funky. I believe they’re stains from brake/carb cleaner and thought it would wipe right off when the time came but unfortunately that’s not the case. This if my first time digging this deep into an engine so I don’t really know if this is normal/acceptable or what I need to do to clean it. Really not looking to hone this thing, I’ve had it apart long enough and don’t want to dig in to the bottom end so please tell me this thing’s ok or that there’s a simple solution.
Thanks guys.
-Evan
Old Feb 21, 2018 | 05:27 PM
millball's Avatar
The staining/discoloration means nothing, fogeddaboudit.
Absolutely DO chase the head bolt hole threads with a tap and clean with compressed air before reassembly.
Degrease the head and block deck with acetone and install new gasket clean and dry!!
Old Feb 21, 2018 | 05:47 PM
Crockpot's Avatar
That’s exactly the answer I was looking for thanks so much.
Old Feb 21, 2018 | 05:49 PM
Crockpot's Avatar
Do you think i can sub out acetone for brake cleaner? Don’t have any acetone on hand.
Old Feb 21, 2018 | 06:41 PM
millball's Avatar
Brake cleaner oughtta do, but acetone or lacquer thinner are best.
Old Feb 22, 2018 | 12:10 PM
Crockpot's Avatar
Sweet. Thanks again.
farrier
Apr 9, 2017 05:23 AM
tonetti
Apr 1, 2010 08:30 PM
PAULV3
Jun 19, 2004 07:31 PM
