Hello,
first time posting here. New to engine building and I always like to learn as I go and buy getting my hands dirty.
I picked up this 22re for a rebuild project and the only issue was it was seized, everything else looked good so I got it anyways hoping for the best.
I tore it all down and kept everything organized, when i was taking out the pistons and crankshaft I found a spun(melted/fused) rod bearing
And a spun crank bearing
No big deal those are easily replaced/fixed so that's not my main question.
I cleaned up the bearing seats(bearing journals? I don't know what you would call this) and found there to be a small crack on both sides of the oil passage.
So my question: is this fixable? Has anyone fixed this before? What are the costs? Block done for?
Good bearing seat(?) for reference
Also what is this spot on the block called? I'd like to be able to research better if I know the terms.
Any information is appreciated and I hope these pictures work.
When I don't know what to call something, I search for "thinganatomy". Most of the time it's because I forgot what it's called or in the case of actual anatomy - never did know.
What did the bearing races look like at the main journal where the crack is? If it looked good then I would assume it was being oiled properly. To me, it depends on how the engine will be used and how much money there is in the budget. That crack might have been there for many, many miles.
I'd find somebody that could magnaflux the block. that would give you the answer you need. I can’t tell very well from the side photo if the “crack” extends very far.
Though many things can be repaired, I don’t think it’s worth the cost. I’d go to a yard and pull an engine to rebuild if that crack is an issue.
Hello,
Thank you.
Spoiler
Have you resolved it? If any students searching for their thesis or research paper here I have the original source where you find all services regarding your essay writing, research paper, dissertation, and your assignments. here you can check the essay writing services review.
