22re coolant in exhaust help
Old Apr 30, 2009 | 06:38 AM
Deez Nutz 08's Avatar
Originally Posted by yodercrawler55
i never thought of bypassing it to test to see if the throttle body is leaking. I'm doin that tonight, if that doesn't work well......then its getting ripped apart.
Just curious to what you found out, I'm stumped and won't be able to tear back into mine for a while.
Old Apr 30, 2009 | 07:05 AM
Lumpy's Avatar
Deez, have you tried running whit the cap loose so it is not to build pressure?
Old Apr 30, 2009 | 07:44 AM
I took the cap all the way off and started it, and let it idle up to operating temp and still no fix, what would that prove of solve anyway, just curious?
Old Apr 30, 2009 | 08:44 AM
Lumpy's Avatar
I was curious about it needing pressure to seep into what ever it's leaking into. Now it seems like it maybe a mechanical issue...not sure what though. So it leaks not matter if it's under pressure or not, just being hot. Seems as if some sort of valve is leaking. I'm running out of ideas. Let's ponder this a while. Hmmmm
How fast is the coolant leaking? Is it real noticeable when you remove the cap?
Old Apr 30, 2009 | 12:15 PM
  #25
Yes the coolant is leaking fast. I think I am going to take the head to a different machine shop and have them check it out too, this is baffling to me that I am about to put this thing up for sale and let someone else stress out about it.
Old Apr 30, 2009 | 03:12 PM
  #26
desert-rat660's Avatar
your intake manifold gasket to cylinder head could be leaking. i made the mistake of not getting all the old gasket material off the manifold before putting it on the head it caused a leak between the coolant passage and my intake port. also if your head was machined too much the head bolts could be bottoming out and not allowing the head gasket to be fully torqued down.
Old Apr 30, 2009 | 06:02 PM
  #27
I will check that out, thanks
Old Sep 13, 2024 | 09:30 AM
  #28
Cam Cook's Avatar
1989 22r
My motor is doing the same thing..lots of antifreeze in exhaust. I pulled the exhaust manifold away from the head and it's just coming out of the number one cylinder????
krimsonone
Sep 13, 2024 09:33 AM
RatOmeter
Oct 22, 2015 03:17 PM
Dakotaneu
Jul 27, 2015 12:03 AM
ryerye13
Jul 14, 2015 08:27 AM
