22RE code 41 and 42, rough idle
Old May 15, 2008 | 04:51 PM
  #61
ahickman's Avatar
Yeah, the engine will surely die as the fuel pump will shut off as well as the ECU can not gauge the air intake and properly adjust the injector duration (amount of fuel). To test the VAF, you don't need the engine running.
Old May 15, 2008 | 04:56 PM
  #62
crews462's Avatar
Thanks Aaron, Do the checks tommorow at work, seemed so simple as something like fuel, but nothing is easy. Seems you follow one lead and get your mind set and it's hard to go another way.
I'll post some pics too.
Old May 15, 2008 | 04:58 PM
  #63
thook's Avatar
Ah.....well.....I was going to say,"but, Aaron....my truck didn't die". But, my COR is permanently on! Right.....doh!
Old May 15, 2008 | 05:00 PM
  #64
abecedarian's Avatar
Originally Posted by crews462
My truck has been having the same problem, in vermont we have the winter thaw, so I was thinking I was getting bad gas. I've changed the fuel filter, cap and rotor and wire set, plugs too. It seems when I put injector cleaner in the problem seems to go away. It did it again on the way home from work tonight and maybe my TPS is going too. I just thought it could be a poor fuel issue.
It's possible that a sudden change from winter gas to summer gas has hit you. It's also possible that the warmer temps are causing more condensation in the gas station tanks and you're getting some water in with your gas. The injector cleaner probably masks whatever is going on since it burns easier than gasoline and compensates a bit for some water. If I were worried about water in the tank, I'd add a pint or two of isopropyl alchohol to the tank every fill-up or two- it mixes the water into the gas and carries it away into the engine and out the tail pipe.
Originally Posted by 89trknwby
I'm not trying to highjack this post, but, if you pull the plug off the afm while running won't the motor die anyway? I'm new to toyota's and have a similar problem. Also , thanks for the input abe. I didn't know that it worked like that. Thanks.
Yeah, if you pull the AFM you'd think it would die, but the system could still be energized through the idle air valve (keep in mind, I'm looking at a general circuit diagram, not the specific one for any vehicle- I'll find a more specific diagram when I know the year of the vehicle in question) or through the ignition switch itself if the COR is failing.
Originally Posted by ahickman
Abe, unfortunately it is the coil that provides the tension that broke away. The center post is now "free-flowing". I have it (VAF box) on my desk and am looking it over to see if or how I can pull it apart to try a repair.
You're probably AFU with the AFM ATM... lol. Once that spring comes loose, you'll be hard pressed to get everything back together.
Old May 15, 2008 | 05:01 PM
  #65
ahickman's Avatar
I have the VAF completely dissasembled and don't think the repair can be made. The metal band is made of hard steel and the holder is plastic. Only thing I can think of is to drill a pinhole and set a small jewels screw. Just not enough material to work with and think it will only break somewhere down the road. Since this is a sealed unit, I doubt Toyota would sell the $5 part needed to fix it. If you know some Joe that would have a used VAF for a good price, by all means send me the contact info. Thanks.
Old May 15, 2008 | 05:05 PM
  #66
You may be able to reinsert the spring into the vane shaft and add tension to it in order to get the vane responding properly, you'll just have to ensure that if and/or when you do, you get that spring permanently mated with the AFM shaft.
whoops, missed your reply.
I don't know anyone in your area with one. There is a wrecking yard up in Rancho Cordova, California that has a lot of toy parts and they may have one and will ship to you https://www.yotatech.com/forums/f123.../#post50716916
I think I gave you this link for an ECU....
Old May 15, 2008 | 05:06 PM
  #67
crews462's Avatar
So you think my initial diagnosis could be correct of the poor fuel. Should I stop using the fuel injector cleaner altogether. Switch to isopropyl alchohol and run the tests on the vam and tps, should solve the problem, hopefully!
THanks
Old May 15, 2008 | 05:10 PM
  #68
THanks
A few bucks spent on fuel system drier mixes or even isopropyl alcohol (they're mostly the same thing) is better than spending hundreds on replacing parts you don't need.
I'd say use the driers/alcohol for a few tanks, then if the problem doesn't go away with a full (and I mean FULL tank) start looking at other things, like testing the TPS etc.
Old May 15, 2008 | 05:12 PM
  #69
89trknwby's Avatar
wow, thanks for all of the info. I have a 89 4x4, 5spd. 22re. I'm going to test the tps and the afm in the morning. THANKS!!
Old May 15, 2008 | 05:14 PM
  #70
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Should give you something to work with.
Old May 15, 2008 | 05:29 PM
  #71
ahickman's Avatar
For those interested, here is a picture of the coil and AFM shaft lock that broke.
http://i303.photobucket.com/albums/n...BrokenCoil.jpg
Old May 15, 2008 | 05:31 PM
  #72
YEP! That'll ruin an engine's drivablility, fuel mix, yadda-yadda-yadda....
The sad thing is that the spring is set in such a way that if it fails, it just pulls out of the housings. It would've been nice if it had say, a 90 kink in the end of it.
Old May 15, 2008 | 05:36 PM
  #73
Let me be the first to say:
"It's worked so far, but we're not out yet."
(+10 points to the first to report the song that's from)
Old May 15, 2008 | 05:44 PM
  #74
ahickman's Avatar
Uh, if it didn't break they would never get to sell the replacements for $800 would they? I agree. There ought to be a hook or even better metal to metal contact. Not sure why they chose to use plastic around the shaft either. Metal would have been better.
Old May 15, 2008 | 05:53 PM
  #75
Yeah, I suppose, but if they made it a bit better... by spending that extra 12 cents to fold an angle into that spring... then they could've raised the cost of the trucks a grand at least, no?
Old May 15, 2008 | 06:03 PM
  #76
thook's Avatar
Hey guys....intentional, yet short lived hijack here....sorry, Aaron.
During my rebuild (22re) I lost the dipstick. I had one for a V6, so cut it long enough and stuck it in. Well, I'm at the 500mi marker for the first oil change on break in. I'd go by the amount of oil to mark my "new" stick, but I'm on unlevel ground.
Would one of you guys get me the measurements for the dipstick? From tip to top, from tip to low level, and tip to full?
  #77
ahickman's Avatar
Abe's comment about a 90 degree angle got my wheels in gear. Flipped the plastic piece over and bent the coil over. Seems to retain tension over the full swing across the resistor pad. Temporary, but might get my daughter and I to Bruster's for an ice-cream tomorrow night!
http://i303.photobucket.com/albums/n...coilrepair.jpg
Old May 15, 2008 | 06:29 PM
  #78
Hope I didn't make you wait too long. I'm going out to my truck right now- it's 7:29 pm pacific time. I'll measure from the 'end' of the dipstick to the 'low' mark and to the 'full' mark.
  #79
ahickman's Avatar
Two pics of the dipstick lying on a tape measure.
http://i303.photobucket.com/albums/n.../dipstick1.jpg
http://i303.photobucket.com/albums/n.../dipstick2.jpg
Tip of dipstick at 2"
Low mark at 2-5/8"
Full mark at 3-1/4"
Top of stick (grommet) at 16-3/8"
Total depth (grommet to end of stick) is 14-3/8"
Old May 15, 2008 | 06:38 PM
  #80
from tip of stick to 'low': 3/8 inch
from tip of stick to 'high': 1 5/8 inch
from tip of stick to dipstick 'stopper': 14 1/4 inch
yikes... big differences....
