22re broken timing scale?
Old Feb 20, 2013 | 07:03 PM
kawasakimoto_7's Avatar
so i was at the smog shop today (didnt pass) emissions i was off by one point, on the hydrogen part... and they said i had a broken timing scale?
do any of you guys know where i can get one besides toyota and maybe how much it would cost me?
Old Feb 20, 2013 | 07:40 PM
yodafan93's Avatar
pretty sure a "timing scale," isnt a part of the timing system. maybe they were trying to say your timing is off?? idk what to tell you dude. only thing i can imagine is the timing lines on the oil pump are possibly wrong? but i dont understand how that could be. and if that's the case just get an oil pump.
Old Feb 20, 2013 | 08:14 PM
scope103's Avatar
I believe the timing mark is read against the oil-pump cover, so that might be what k...7 is referring to with "timing scale." The Toyota part can be found here: http://www.toyotapartszone.com/oem/t...115-35020.html
RockAuto has an entire oil pump for less than $50.
Hydrogen part? Paraphrasing Mark Twain, I believe that hydrocarbons is as close to hydrogen as lightning is to a lightning bug.
Old Feb 24, 2013 | 09:54 PM
i guess its just a cast iron part that has the lower timing mark on it... really hard to see though without pulling the radiator and such or else i would get a picture of it...
on another subject my truck kinda just sits in the garage and doesnt move anymore so maybe thats why it failed so i was probably going to run sea foam through it and hopefully clear up the carbons enough to pass
http://www.4x4wire.com/toyota/mainte...n/image011.jpg
thats a google image of the piece that isnt there, looks like maybe it just unbolts
Old Feb 25, 2013 | 10:36 AM
Co_94_PU's Avatar
Yeah that is the part they were talking about above, it's part of the oil pump casting. You can get a good angle/photo from the battery area or shove the camera down there.
For your HC issue I'd suggest a full tune up with oil change and a good long freeway drive before the test. Seafoam will make it worse especially if you don't change the oil between the treatment and test, since it's basicly kerosene IIRC.
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
bryan34w
Jul 6, 2015 05:53 PM
HRDC0R19
Jul 5, 2015 06:43 PM
