22re blown head gasket?
Old Sep 30, 2008 | 08:14 PM
ringading's Avatar
I have searched the forum and am pretty sure that my head gasket is blown or my head is cracked. Last week the truck started overheating on the freeway so I started to pull over. As I was pulling over my upper radiator hose blew. I fixed that and filled it back up with coolant. The next day I drove just a couple miles and it started overheating again and then died. Few hours later was able to start the truck and drive the two blocks home. So when I started looking at it I soon found that there is a lot of coolant in my oil. My guess is the head gasket is blown. Maybe cracked head because of the overheating? Don't think its the timing chain because there was no noise from it. The engine has almost 200,000 on it. Is there anything else it could be. Should I just tear into it and take the head into the machine shop to get checked out? What are all the gaskets that I am going to need and what brand should I get? What other parts should I replace while I am in there? Plan on tearing into it in a day or two and taking lots of pics. Thanks for all the help!
Old Sep 30, 2008 | 08:25 PM
ozziesironmanoffroad's Avatar
compression check it
Old Sep 30, 2008 | 09:04 PM
ringading's Avatar
Thanks. I'll pick one up tomorrow and post what I find.
Old Oct 1, 2008 | 12:59 PM
spknucklehead's Avatar
on the comp test whats ideal for these motors
Old Oct 1, 2008 | 01:03 PM
annoyingrob's Avatar
As long as you're +-5psi on the cylinders you're fine. Heck, even 10. If you see one at 140, and another at 20, you know you have a problem.
I know you said there wasn't any noise coming from the timing chain, but I would look at that too.
Old Oct 1, 2008 | 01:33 PM
okie81's Avatar
Water vapor/condensation coming out of the rear pipe? Maybe you dug into a water sleeve?
Old Oct 1, 2008 | 06:47 PM
ringading's Avatar
I don't think there was any condensation coming out of the pipe but I'll check. Will hopefully have the compression results tomorrow.
Old Oct 5, 2008 | 03:08 PM
ringading's Avatar
Here are the compression test results.
1 = 148
2 = 143
3 = 155
4 = 128
What do you guys make of it?
Old Oct 5, 2008 | 03:38 PM
91lowyota's Avatar
yeah you deffinelty need a new head gasket, you should do your timming chain since your tearing the head off.
Old Oct 5, 2008 | 05:21 PM
Wouldn't be a bad idea to get new head bolts while you're at it.
Old Oct 5, 2008 | 05:31 PM
ringading's Avatar
Any recommendations on where to get the gaskets, head bolts, and timing chain?
Old Oct 5, 2008 | 06:00 PM
engine builder or the stealership
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
