22R won't run after rebuild
Old Jul 4, 2008 | 08:21 PM
mckk's Avatar
Need help!! Just rebuild 91 toyota 22r. Everything back together and it will run for a second or 2 and then quit. Any ideas??
Old Jul 4, 2008 | 09:20 PM
abecedarian's Avatar
is the air flow meter plugged in?
Old Jul 5, 2008 | 06:56 PM
Georgiadave's Avatar
1. Are you sure you have everything reconnected properly?
2. Is your check engine light on? If so, what are the codes?
3. It sounds like a fuel problem, but I am not looking at the engine.
Old Jul 5, 2008 | 07:59 PM
TOYOTA 1's Avatar
x2
Old Jul 7, 2008 | 02:03 PM
JoelNorton's Avatar
When I changed my motor I started it without the Mass airflow senser plug hooked up. It wouldn't run more than 5 seconds, even after I hooked everything up. I messed around with the wires for a couple hrs, no luck. When I finally erased the check engine light it ran perfect. I think you disconnect the battery or jump the check plug, can't remember.
bigjstang
Jun 2, 2025 03:56 PM
jerusry
Oct 19, 2015 05:28 PM
Yota.Jay
Jul 23, 2015 08:08 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
karbin
Jul 5, 2015 11:37 PM
