22R won't run after rebuild
When I changed my motor I started it without the Mass airflow senser plug hooked up. It wouldn't run more than 5 seconds, even after I hooked everything up. I messed around with the wires for a couple hrs, no luck. When I finally erased the check engine light it ran perfect. I think you disconnect the battery or jump the check plug, can't remember.
jerusry
Oct 19, 2015 05:28 PM
